4 Replies Latest reply on Jul 25, 2011 1:07 PM by roestigraben
    Problem with Release build
    roestigraben
      Hello,
      I was so happy to finish my application as it worked exactly like I intended it to do......until I wanted to make a release build.
      When I open the project.html (or also the swf file standalone) in the browser, it tells me the below message.
      I tried with some other projects and I noticed that it has to do with the fact that I am using an SQL database access in the case when it does not work.
      Can you give me a hint
      BR
      Peter
        • 1. Re: Problem with Release build
          kokorito Level 4
          doesnt it say the invalid arguement is the url http:gateway.php
          that doesnt look right, shouldnt it just be gateway.php
          if you are developing using a local server then you might need to change things when its live on a remote server
          • 2. Re: Problem with Release build
            roestigraben Level 1
            Hello,
            the problem is there when I simply go from a debug into a release build.
            When I open the swf or html wrapper file, I immediately get this error.
            Does it have to do with some settings on FlashBuilder. I still use exactly the same stuff except that some debug capabilities are taken out when I do a release build.
            thanks for some comments or hints
            Peter
            • 3. Re: Problem with Release build
              kokorito Level 4
              the debug version is published to a different folder to the release version, which ultimately needs to be deployed to a server
              • 4. Re: Problem with Release build
                Sorry to insist.
                Yes, the bin-release is a different folder comapred with the bin-debug.
                But I should be able to open the wrapper file and see the application work.
                It does not work with the said error message.
                So, I am exactly in the same environment, simply i launch the application from bin-release and here I have my problem.
                Many thanks for your continued help
                BR
                peter
