2 Replies Latest reply on Jul 25, 2011 5:44 AM by j@i
    error during tooltip on datagrid
    j@i
      hi everyone,
      I'm trying to get tooltip on datagrid mouse over item with item data in it.But its generating some runtime error.its given here in bold
      Argument count mismatch on DataGrid_ToolTip/buildDataTip(). Expected 1, got 2.
      colud any one plz help on it.
      thankyou,
         xmlns:mx="library://ns.adobe.com/flex/mx"
         creationComplete="application2_creationCompleteHandler(event)">
      <fx:Script>
      <![CDATA[
      import mx.collections.ArrayCollection;
      import mx.events.FlexEvent;
      import mx.rpc.events.ResultEvent;
      [Bindable]
      public var empArray:ArrayCollection =new ArrayCollection();
      /* protected function empData_resultHandler(event:ResultEvent):void
      empArray = event.result.data.employee;
      protected function application2_creationCompleteHandler(event:FlexEvent):void
      empArray.addItem({name:"Srini",exp:"1",degination:"Software Engineer"});
      empArray.addItem({name:"Afzal",exp:"1",degination:"Software Engineer"});
      empArray.addItem({name:"Nag",exp:"1",degination:"Software Engineer"});
      public function buildDataTip(item:Object):String
      var myString:String = "";
      if(item != null)
      myString = myString+ "Name : "+item.name;
      myString = myString+ "Experience : "+item.exp+"/n";
      myString = myString+ "designation : "+item.degination+"/n";
      return myString;
      </fx:Script>
      <fx:Declarations>
      <!-- Place non-visual elements (e.g., services, value objects) here -->
      <!--<s:HTTPService id="empData" url="data/data1.xml" result="empData_resultHandler(event)"/>-->
      </fx:Declarations>
      <s:VGroup width="100%" height="100%" verticalAlign="middle" horizontalAlign="center">
      <s:DataGrid id="empDetails" dataProvider="{empArray}" requestedRowCount="10" width="50%"
      dataTipFunction="buildDataTip">
      <s:columns>
      <s:ArrayList>
      <s:GridColumn dataField="name" headerText="Name" showDataTips="true"/>
      <s:GridColumn dataField="exp" headerText="Experience" showDataTips="true"/>
      <s:GridColumn dataField="degination" headerText="Designation" showDataTips="true"/>
      </s:ArrayList>
      </s:columns>
      </s:DataGrid>
      </s:VGroup>
      </s:Application>
        • 1. Re: error during tooltip on datagrid
          Pooja Kuber Level 2
          Add one more parameter in the buidDataTip function, since
          the signature of the dataTipFunction function for Spark data grid is as follows:
          dataTipFunction(item:Object, column:GridColumn):String
          public function buildDataTip(item:Object,column:GridColumn):String
          if(item != null)
          return myString;
          Thanks and Regards,
          Pooja Kuber | pkuber@infocepts.com | www.infocepts.com
          • 2. Re: error during tooltip on datagrid
            j@i Level 1
            hi pooja,
            thanks alot,its working.
