1 Reply Latest reply on Jul 25, 2011 8:38 AM by Steve Werner
    Indesign CS4 & Mac osx Lion Issue
    azerty11800
      I migrated to Mac OSX Leo last week, I use Indesign CS4 6.0.6. Since then, I can not open my projects Indesign CS4 (indd): error code 4, file damaged. None of my projects can not be opened, every time I have the same error code.
      I downloaded the trial version of InDesign CS5 to test it, and actually open my projects well with CS5. If I export themas. IDML, at the time CS4 opens the file.
      I do not understand anything, anyone has a solution?
      Thank you,
      Gaelle
        • 1. Re: Indesign CS4 & Mac osx Lion Issue
          Steve Werner Adobe Community Professional & MVP
          I have Lion installed on my secondary computer, an iMac.
          I just tested opening a few files in CS4, and it works fine.
          You may need to reinstall CS4. But because you also installed the CS5 trial, you should uninstall that as well. To do this on a Mac, go to /Applications/Utilities/Adobe Installers and uninstall both CS4 and CS5.
          Then use your original install discs and install CS4 again.
