3 Replies Latest reply on Jul 25, 2011 1:47 PM by lasvideo
    AJA Kona Support in Premiere CS5.5
      I'm new to Premiere, and I've encountered some unexpectedly poor performance that I'm currently attributing to my AJA Kona 3, but I'm wondering what I can do about it. I downloaded a trial of CS5.5 and installed the latest AJA drivers (9.0.3) and Adobe plug-ins (9.0.1). Here's my system configuration:
      Mac Pro 4,1
      2 Xeon 2.93 Ghz
      16 GB RAM (10 GB allocated to PP/AE/AME)
      OSX 10.6.5
      AJA Kona 3
      No CUDA-enable GPU
      External RAID storage array w/ fiber interface
      I'm working with a mix of source materials - XDCAM EX footage, ProRes 422 or Animation graphic renders, DVCPro HD or Uncompressed captures - all at 1080/59.94i
      For starters, sometimes I have clips that shouldn't have to render that begin stuttering or failing to play, but after I stop and attempt to play that portion again, it works fine. This becomes very problematic during Export to Tape operations, when it can play through most of a sequence then hang up at the end. It seems most prone to this when switching between video codecs in the same sequence where they are not marked with any render-indicating color. I assume this means the Kona is handling those clips and should be able to play them without any problems. Is there some configuration issue I should look at that will address this? Maybe RAM allocation?
      Secondly, I can't figure out how to output timecode via the 9-pin RS-422. It seems that Premiere is not sending any timecode information to the Kona, because when I enable timecode overlay from the AJA Control Panel, it doesn't show anything. If I open a Quicktime file using AJA TV, the timecode will display as expected. Is there a configuration option within Premiere that I'm overlooking? Not offering TC output seems like it would be a major oversight, so I'm assuming this is something I simply can't figure out.
      Third, I'm experiencing an odd issue when scrubbing the sequence to find edit points in the audio. When I scrub frame-by-frame, it seems that the audio being played is always from the frame I just scrubbed FROM, not the frame I scrubbed TO (i.e., the current frame). This is not intuitive, and also not how Premiere works in non-AJA sequence presets. I'm assuming that this is just an AJA bug, but wanted to mention it in case I'm overlooking something.
      I know this is a lot for one thread, but I appreciate the community's time, expertise, and help. I really am excited about working with Premiere instead of FCP, but these issues can be frustrating.
