5 Replies Latest reply: Jul 26, 2011 7:59 AM by kglad RSS
    Similar concepts in Actionscript 3.0
    Kirubakaran Srinivasan Community Member
      Hi
      I would like to know onething over here that in AS3 we have many similar concepts like below followings
      These things are some kind of confusing concepts. If we understood these concepts very well then we can Optimize our coding by ingoring unwanted useages.
      1. Timer - setInterval
      2. EventDispatch - Dispatchevent
      3. loader - URLLoader
      4. overload - override
      5. Sprite - MovieClip - DisplayObject - DisplayObjectContainer
      If you know more than these things please and revert me back.
        • 1. Re: Similar concepts in Actionscript 3.0
          Desmond666 Community Member
          I said from the VERY start that I was new to Flash.
          I didn't say that I was totaly ignorant of any programming language. I have
          usded
          C/C++
          VB
          VB.NET
          C#
          to name a few
          I know about classes object orientated programming scope overloading
          namespaces implcit and explict casting as well as interfaces.I know about
          imports.
          Does anyone know what these do?
          import flash.display.Loader;
          import flash.utils.Timer;
          Because they are in my code and the following does not work
              var imageLoader:Loader;
          imageLoader = new Loader();  // Error dosen't understand previouse  line.
          var myTimer:Timer = new  Timer(2000,8);
          myTimer.addEventListener(TimerEvent.TIMER,  timerListener);  // Error
          D:\MoveSlides\code\MovieSlides.as, Line 19 1120: Access of undefined
          property imageLoader.
          D:\MoveSlides\code\MovieSlides.as, Line 21 1120: Access  of undefined
          property myTimer.
          My knowledge of programming says something is wrong here.
          Desmond
          In a message dated 26/07/2011 14:25:56 GMT Daylight Time, forums@adobe.com
          writes:
          Hi
          useages.
          • 2. Re: Similar concepts in Actionscript 3.0
            kglad CommunityMVP
            use the timer class.  you're less likely to have a scope problem.
            use dispatchEvent() to dispatch an event.
            there is no EventDispatch.  there's an EventDispatcher class that consists of objects that can use dispatchEvent().
            use the Loader() class to load a displayobject (like a bitmap or swf) and use the URLLoader() class to load data (like xml, text and call executables)
            use override to replace an inherited method
            overloading can't be done in as3.
            roughly:
            DisplayObject:  anything that can be added to the stage which includes all below
            DisplayObjectContainer:  anything that can be added to the stage and can contain child objects
            Sprite:  a displayobjectcontainer that can be dragged
            MovieClip:  a sprite with a timeline
            details:
            check each class in the help files.  as you move from top of my listing to the bottom you'll see each class adds more properties, methods and events.
            • 3. Re: Similar concepts in Actionscript 3.0
              as in
              import flash.utils.Timer;  ???
              Desmond
              In a message dated 26/07/2011 14:44:44 GMT Daylight Time, forums@adobe.com
              writes:
              • 4. Re: Similar concepts in Actionscript 3.0
                Hey guys
                Here i dont want any explanation. but i need more similar topics like the below topics
                Only this thing i m expecting from this discussion.
                No explanation, only needs more similar concepts/topics in AS3.0
                • 5. Re: Similar concepts in Actionscript 3.0
                  kglad CommunityMVP
                  please mark helpful/correct responses, if there are any.
