4 Replies Latest reply on Jul 26, 2011 12:23 PM by kglad
    Image faid in/out
    Desmond666
      Hi I am new to flash but have created a powerpoint stly presentation of images. I Have a Movie Clip on the stage. Is it possible to get a fade in/out effect on the images. The actual work horse here is actionscript file that uses the following
              function imageLoaded(e:Event):void
                  imageArea.addChild(imageLoader);
      Where imageArea is the reference to the Movie Clip.
      Desmond.
        • 1. Re: Image faid in/out
          you can use something like:
          var t:Timer=new Timer(70,0);
          t.addEventListener(TimerEvent.TIMER,f);
          imageLoader.alpha=0;
          t.start();
          function f(e:TimerEvent):void{
          imageLoader.alpha+=.04;
          if(imageLoader.alpha>=1){
          t.stop();
          // remove listener and null t if not needed again.
          imageLoader.alpha=1;
          • 2. Re: Image faid in/out
            Desmond666 Level 1
            Hi Thanks for that. I already have a timer that goes through a loop getting the next image for the MovieClip on the Flash stage. I have seen some websites where one image slowly faids out and another faids in. Is this done as a repeat movie or is this something I can do with a series of images in a folder.
            I have the complete CS5.5
            Desmond.
            Another thought. If I have two movieClips on the stage and two imageLoders could I alternate between them have an alpha faid out on one and a faid in on the other. Would this be a solution ?????
            • 3. Re: Image faid in/out
              for a cross-fade, you need at least 2 loaders so you can fade one in while fading the other out.
              • 4. Re: Image faid in/out
                Desmond666 Level 1
                Thanks I added that to my query as a possible solution. two MovieClips, two
                Loaders and to variables for the alpha values crossing over on a short
                timer  event. Wasn't sure if having two MovieClips on a stage with one behind
                the other  it would show through?
                Desmond
                In a message dated 26/07/2011 20:24:32 GMT Daylight Time, forums@adobe.com
                writes:
