7 Replies Latest reply on Jul 27, 2011 2:44 AM by jeanmed
    page number (search function)
    jeanmed
      Dear,
      I need to creat a script who search all  words who use the test character style.
      In my script it works but i dont fond the way to load the page number of the elements founded.
      My code :
      var list=new Array();
      app.findTextPreferences = app.changeTextPreferences = null;
      app.findTextPreferences.appliedCharacterStyle = "test";
      return = app.activeDocument.findText();
      var msg="";
      for (i = 0; i < retour.length; i++)
          msg+=return [i].contents+" - "+return [i]. // here the page number //+"\r";
      alert(msg);
      Thanks for your help
        • 1. Re: page number (search function)
          csm_phil Level 4
          Hi Jean,
          I have to modified you JS Code, please try and get correct you expect the result.
          var mySearch = app.activeDocument.findText();
          var msg="";
          for (i = 0; i < mySearch.length; i++){
              msg+=mySearch[i].contents+" - "+mySearch[i].parentTextFrames[0].parent.name+"\r";
          alert(msg);
          thanks
          csm_phil
          • 2. Re: page number (search function)
            jeanmed Level 1
            Thanks for your help !
            Do you  know how to do search between different pages exemple from 10 to 15.
            Thanks a lot
            • 3. Re: page number (search function)
              csm_phil Level 4
              Hi Jean,
              i have updated my script as per your above mentioned request.
              Please try this js code and revert for further help?
              var myPage = myDoc.pages;
              var msg="";
                   try{
                        var mypage = mySearch[i].parentTextFrames[0].parent.name;
                        }catch(e){}
                   if(mypage>=10&& mypage <=15){
                        try{
                             }catch(e){}
              alert(msg);
              thx
              csm_phil
              • 4. Re: page number (search function)
                jeanmed Level 1
                Dear,
                This code dont works width CS5 : mySearch[i].parentTextFrames[0].parent.name
                Do you have an idea ?
                • 5. Re: page number (search function)
                  Adobe-InDesign CS4 Level 1
                  Dear Ieanmed,
                  Please use the below code: CS5
                  //==================== Code=================//
                  mySearch[i].parentTextFrames[0].parentPage.name
                  Regadrs
                  T.R.Harihara SudhaN
                  • 6. Re: page number (search function)
                    csm_phil Level 4
                    Hi Jean,
                    You can't mentioned your using CS5, i am giving the code is working in cs3/cs4 only. Because the CS5 give the short method of "parentPage". So hari mentioned the correct way in CS5.
                    You expect the page range is working or not? has i was post my previous code.
                    thx
                    csm_phil
                    • 7. Re: page number (search function)
                      jeanmed Level 1
                      Thanks a lot !
