Hello,
I'm on WS2008 (64-bit) with IIS and CF9.0.1 (32 bit) and can't seem to get a bound CFSelect to work at all. CFGrid and other AJAX contriols work great. The code (shown below) appears to run without errors but the option tags are never generated.The binding CFC method returns a query with the data I want (I can see it on a dump) but is dropped by CF somehow.
Ideally I want to use this approach on several complex forms but need to get something working first. Removing the lookup doesn't help either. I'm pulling this Oracle data via the 10G Client's ODBC driver.
I've been working on CF forever (4-9) and never was stumped like this. Otherwise CF 9 On this server is running without a hitch.
Long term I'm trying to move away from our Flash/Actionscript equivilants and move toward AJAX. But I'm stuck. Please help!
Tim
Index.cfm
__________________________________________________
<cfparam name="form.lookup" type="string" default="A">
<cfform preservedata="Yes">
Search: <input type="text" name="lookup" id="lookup"><br />
<cfselect name="Emp" bind="cfc:application.getEmpList({lookup})" value="EMPL_NBR" display="EMPL_NM">
<option value="00000000">--- No Employees ---</option>
</cfselect>
</cfform><br>
<!--- Just for Testing --->
<cfinvoke component="Application" method="getemplist" returnVariable="qRead">
<cfinvokeargument name="likename" value="#form.lookup#">
</cfinvoke>
<cfdump var="#qRead#" output="browser">
Application.cfc
_____________________________________________________
<cffunction name="getEmpList" access="remote" returntype="query" output="yes">
<cfargument name="LikeName" type="string" required="yes">
<cfquery name="Emps" datasource="#application.dsn#" maxrows=50>
Select EMPL_NBR, EMPL_NM from MNDOT_EMPLOYEE
Where EMPL_STAT_CD = 'A' <cfif isdefined("LikeName")> and upper(Empl_Nm) like '%#ucase(likename)#%'</cfif>
Order By Empl_NM</cfquery>
<cfreturn emps>
</cffunction>
Message was edited by: CFTim1965
Update: If I remove our template (stardards from our CO) all works well. It won't generate the Javascript if the template is used.
Turns out that bound (used for the CF AJAX tags) CFCs are processed by the Application.cfc event methods like CFMs are and will have any HTML tags added in. When my method returned the query it had all my template code at the top (and some on the bottom). I used the code (in the Application.cfc) below to only write the HTML when the CFM pages are processed. Hope this helps! There a lot of misleading half truths out the about this issue.
<cffunction name="onRequestStart">
<cfargument name="targetpage" type="string" required="true">
<cfset var isCFM = (lcase(ListLast(arguments.targetPage, '.')) eq 'cfm') />
<cfif isCFM>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<body>
<cfset AppHeader() /><!--- Create the Template Header --->
</cfif>
</cffunction>
I don't think it's a very good idea to output mark-up in the event handler methods (or, indeed, any method). onRequestStart() is better used for setting up variable values specific to a request, but leave view CFM templates to handle mark-up. If I had to output mark-up in Application.cfc, I'd use onRequest instead of onRequestStart.
Incidentally, if you're running CF9, you should implement a onCfcRequest handler - http://help.adobe.com/en_US/ColdFusion/9.0/CFMLRef/WSe821657cd7d6f83f6daaa733122cf6931bb-8000.html - which will be called instead of onRequest.
Such as?
Adam
I just saw that today too! FWIW: I wish there were a "OnCFMRequest" instead. IMHO that would be more useful. What would need to be added/done to every method in a cfc? Especially when I specify a return type.
I only found the out about the issue when the CFAjax,js error started showing up and I found the bug report. The description led me to believe that Application.cfc didn't process cfincludes correctly somehow. I'm not even sure of it's a "Bug" in the traditional sense.
I feel like I need to prepare the page structure way before the meat of the request is processed.
Ah, well onCfcRequest was implemented as a fix for the fact that when one has an onRequest handler, it buggered up any CFC request. It's only reason for being is to block onRequest from running in those situations.
It's not a bug. It's just an artifact of on oversight on the part of CF when onRequest was first implemented.
Adam
