2 Replies Latest reply on Jul 27, 2011 11:04 AM by FTQuest
    buttonMode in Safari 5.1 problem
    FTQuest Level 3
      Hello there,
      This morning after updating to the latest Safari 5.1 I encountered a problem with using 'buttonMode=true": the cursor does NOT revert to default after leaving the control.
      Here is barebone example:
         xmlns:mx="library://ns.adobe.com/flex/mx"
         minWidth="955" minHeight="600">
      <s:layout>
      <s:VerticalLayout horizontalAlign="center" gap="40" />
      </s:layout>
      <s:Button label="ButtonMode True" buttonMode="true" />
      <s:Button label="ButtonMode False" buttonMode="false" />
      </s:Application>
      I'm using OS 10.6.8
      Would appreciate any suggestion for workaround.
      thanks,
      Igor Borodin
        • 1. Re: buttonMode in Safari 5.1 problem
          Peter Blazejewicz Level 4
          Hi Igor,
          can you test if this is happening with consumer-grade plugin (non-debugger version) as well? There could be something with debugger version of runtime, see e.g.:
          http://forums.adobe.com/message/3820840?tstart=0
          (so you would hit issue that could be filled as bug but your customers won't)
          kind regards,
          Peter
          • 2. Re: buttonMode in Safari 5.1 problem
            FTQuest Level 3
            Hi Peter,
            Thank you for the reply.
            Judging by your question I gather that you could not reproduce the problem - hand cursor not reverting to default arrow upon leaving the interactive control.
            If you couldn't, then it's indeed a relieve, because it means the problem is within my iMac.
            As to the debugger version, the problem shows up in both versions (after discovering it I reinstalled both with the latest FP).
            I also checked the behavior on couple of sites, where viewsource is enabled - like Peter deHaan's flexexamples - the same story: if 'buttonMode' is 'true', once the pointer turns into the handCursor, it does not return to default arrow.
            Please, confirm that you indeed could NOT reproduce the problem.
            BTW, it's only Safari; both Firefox and Chrome are working fine.
            Igor Borodin
            Update:
            Apparently, there IS a problem: here is the thread from Apple Support Communities:
            https://discussions.apple.com/thread/3191466?start=0&tstart=0
