5 Replies Latest reply on Dec 3, 2012 1:47 AM by Paul Riggott
    Combining two images like picture package and run it for all the images inside a folder
    nesselkus
      I have hundreds of jpg photo files in a folder. I  want to resize and combine 2 4.5x6 jpg files into one 4x6 jpg file  containing 2 photos, each 3x4. Then I can upload them and get them  printed by a photo printing service. I can do this by picture package but it takes hours and hours to do it for every couple of image inside a folder. I need to browse for the folder and then the script shall combine every 2 images repeatingly. So if I have 500 images the combined images number shall be 250 totally at the end.
      Do you have any other suggestions? Thanks!
        • 1. Re: Combining two images like picture package and run it for all the images inside a folder
          I think you want to look at contact sheet rather them picture package.  Your images have a pixel size that has a 3:4 Aspect Ratio without cropping they can be printed at any 3:4 aspect ratio size 3x4, 6x8, 4.5x6 just by changing the images print DPI resolution. Pictute Package is used to print several prints of an image as a package containg sever copies of a single image at one or more sizes on a sheet of paper.  Where contact sheet is set up to create image sheets for all images in a folder. If you do not care which two pictures print on a sheet. Try running a contact sheet script for 4x6 sheets that have 2 3x4 images.
          Print programs like qimage can also be used to do that job.
          • 2. Re: Combining two images like picture package and run it for all the images inside a folder
            Paul Riggott Level 6
            This should do the job....
            #target photoshop
            main();
            function main(){
            var inputFolder = Folder.selectDialog("Please select the folder with Files to process");
            if(inputFolder == null) return;
            var startRulerUnits = preferences.rulerUnits;
            app.displayDialogs = DialogModes.NO;
            var outputFolder = Folder(inputFolder + "/Combined");
            if(!outputFolder.exists) outputFolder.create();
            var fileList = inputFolder.getFiles(/.jpg$/i);
            while(fileList.length>0){
            preferences.rulerUnits = Units.PIXELS;
            if(fileList.length==1) break;
            var mainDoc = open(fileList.shift());
            mainDoc.resizeCanvas((mainDoc.width*2), mainDoc.height, AnchorPosition.TOPLEFT);
            var tmp = open(fileList.shift());
            tmp.activeLayer.duplicate(mainDoc);
            tmp.close(SaveOptions.DONOTSAVECHANGES);
            var LB = mainDoc.activeLayer.bounds;
            mainDoc.activeLayer.translate((mainDoc.width-LB[2].value),0);
            mainDoc.flatten();
            preferences.rulerUnits = Units.PERCENT;
            mainDoc.resizeImage(66.66666, undefined, undefined, ResampleMethod.BICUBICSHARPER);
            var saveFile = File(outputFolder + "/" + decodeURI(activeDocument.name));
            SaveJPEG(saveFile, 10);
            mainDoc.close(SaveOptions.DONOTSAVECHANGES);
            preferences.rulerUnits = startRulerUnits;
            function SaveJPEG(saveFile, jpegQuality){
            jpgSaveOptions = new JPEGSaveOptions();
            jpgSaveOptions.embedColorProfile = true;
            jpgSaveOptions.formatOptions = FormatOptions.STANDARDBASELINE;
            jpgSaveOptions.matte = MatteType.NONE;
            jpgSaveOptions.quality = jpegQuality;
            activeDocument.saveAs(saveFile, jpgSaveOptions, true,Extension.LOWERCASE);
            • 3. Re: Combining two images like picture package and run it for all the images inside a folder
              Paul's scritp will work if all images are 4.5x6 Portraits and the script will save files. Where menu File>Automate>Contact Sheet II will leave all sheets open in Photoshop you will need to save them. However as long as the images were shot with a 3:4 Aspect ratio camera it make no difference  what their Print DPI resolution is set to or if they are Landscape or Portrait Contact Sheet II has options to handle it.
              • 4. Re: Combining two images like picture package and run it for all the images inside a folder
                pengzhuozhi
                Hi, thanks for this script, it will be very usefull, but i need vertical instead of horizontal
                I've already changed the bold part in order do double height, but now i cant put the second image at bottom, could you help me?
                Thanks in advance
                #target photoshop
                main();
                function main(){
                mainDoc.resizeCanvas(mainDoc.width, (mainDoc.height*2), AnchorPosition.TOPLEFT);
                mainDoc.flatten();
                • 5. Re: Combining two images like picture package and run it for all the images inside a folder
                  Here you are...
                  #target photoshop
                  main();
                  function main(){
                  mainDoc.activeLayer.translate(0,(mainDoc.height-LB[3].value));
                  mainDoc.flatten();
