1. Re: Lock panel window on right into place
JoyceEvans Jul 27, 2011 10:55 AM (in response to quality11)Try the Window menu "Use Application Window"
2. Re: Lock panel window on right into place
JoyceEvans Jul 27, 2011 10:56 AM (in response to JoyceEvans)If you are talking about the individual panels then click and drag top of panel to the position you want in the Panels bar and release
3. Re: Lock panel window on right into place
quality11 Jul 27, 2011 11:44 AM (in response to JoyceEvans)Hmmm....I'm not sure how to describe it. You know how there's a series of panels on the right? Optimize/History/Align, Pages/States/Layers, Styles/Color Pallette/Swatches, etc? They are one on top of each other to form one big panel? That whole "big panel" will not lock and it just lies there on top of the image even if it's on the far right. When it's locked the image doesn't not go underneath and the panel doesn't hide things in the header and footer section of FW. Does that make sense?
4. Re: Lock panel window on right into place
JoyceEvans Jul 27, 2011 11:49 AM (in response to quality11)You on a Mac? I had that issue as well and the command from the Window menu did it. Windows| Use Application Frame - locked the panel and the Property inspector to the main window.
5. Re: Lock panel window on right into place
quality11 Jul 27, 2011 11:53 AM (in response to JoyceEvans)I'm on a PC. Is it the same solution?
6. Re: Lock panel window on right into place
quality11 Jul 27, 2011 11:56 AM (in response to quality11)I don't have that Application command on my Window drop down by the way:
7. Re: Lock panel window on right into place
quality11 Jul 27, 2011 11:59 AM (in response to quality11)Also...I just clicked "Duplicate Window" from Window drop down and it's grayed out now. How do I turn that off?
8. Re: Lock panel window on right into place
JoyceEvans Jul 27, 2011 12:09 PM (in response to quality11)I never had an issue on a PC but maybe you undocked them all. Try grabbing the gripper and dragging to the right of document window and releasing. I haven't used on a PC in awhile so I am firing it up now:-)
9. Re: Lock panel window on right into place
quality11 Jul 27, 2011 12:11 PM (in response to JoyceEvans)I've done that over and over and can't get it to work.
What about the "Duplicate Window" issue above?
10. Re: Lock panel window on right into place
quality11 Jul 27, 2011 12:13 PM (in response to quality11)I think I finally got it after trying to drag and drop for the tenth time!
11. Re: Lock panel window on right into place
JoyceEvans Jul 27, 2011 12:13 PM (in response to quality11)Do you have a doc open? blank is fine, then check it
12. Re: Lock panel window on right into place
quality11 Jul 27, 2011 12:15 PM (in response to JoyceEvans)Huh? Not following you :-).
13. Re: Lock panel window on right into place
JoyceEvans Jul 27, 2011 12:17 PM (in response to JoyceEvans)Do you happen to have "Cascade" or "Tile" selected in Window menu?
14. Re: Lock panel window on right into place
JoyceEvans Jul 27, 2011 12:19 PM (in response to quality11)You said "Duplicate Window" was grayed out. Be sure you have a blank or opened document, then check and see if it is not grayed out
15. Re: Lock panel window on right into place
JoyceEvans Jul 27, 2011 12:23 PM (in response to quality11)For future reference, when you drag and drop, there will be a thick dark line that appears. This is when you release the mouse or drop.
16. Re: Lock panel window on right into place
quality11 Jul 27, 2011 12:23 PM (in response to JoyceEvans)No cascade or tile selected.
All set though. You got it. Thanks so much for your help, Joyce!!
17. Re: Lock panel window on right into place
quality11 Jul 27, 2011 12:26 PM (in response to JoyceEvans)Thanks Joyce. I'm scared to try it right now for fear I'll mess it up again
but will save this as a reference .
18. Re: Lock panel window on right into place
JoyceEvans Jul 27, 2011 12:28 PM (in response to quality11)Great!! Both issues all set now?
19. Re: Lock panel window on right into place
JoyceEvans Jul 27, 2011 12:30 PM (in response to quality11)LOL. You can practice on one panel. It is also the way you can rearrange the panels. It's how you place in order you want. You can also make or reaarange panel tab groups the same way
20. Re: Lock panel window on right into place
quality11 Jul 27, 2011 12:32 PM (in response to JoyceEvans)Both issues all set now :-).
I'll trust you on that one but will again put this on file when I'm ready to do that.
