8 Replies Latest reply on Jul 29, 2011 9:19 AM by Colin Brougham
    Why doesn't  Premiere like this file?
    jb.uk Level 1
      I'm trying to import a file and Premiere is telling me that it's corrupt or is an unsupported format. Below is the mediainfo output.
      I've been down this road before, and I usually end up on a fruitless search for programs to convert flash to another format. I'm not clear whether it is indeed Flash is causing the problem. I always thought it was the codec which was the important component, and I thought Premiere could handle AVC. Anyway, if anyone could tell me what the problem is, and the easiest way around it, I would be extremely grateful.
      General
      Complete name                    : blahblah.mp4
      Format                           : Flash Video
      File size                        : 172 MiB
      Duration                         : 10mn 18s
      Overall bit rate                 : 2 326 Kbps
      Video
      Format                           : AVC
      Format/Info                      : Advanced Video Codec
      Format profile                   : Main@L4.0
      Format settings, CABAC           : No
      Format settings, ReFrames        : 16 frames
      Codec ID                         : 7
      Duration                         : 10mn 18s
      Width                            : 854 pixels
      Height                           : 480 pixels
      Display aspect ratio             : 16:9
      Frame rate mode                  : Constant
      Frame rate                       : 30.000 fps
      Color space                      : YUV
      Chroma subsampling               : 4:2:0
      Bit depth                        : 8 bits
      Scan type                        : Progressive
      Audio
      Format                           : AAC
      Format/Info                      : Advanced Audio Codec
      Format profile                   : LC
      Codec ID                         : 10
      Duration                         : 10mn 18s
      Channel(s)                       : 2 channels
      Channel positions                : Front: L R
      Sampling rate                    : 44.1 KHz
      Compression mode                 : Lossy
