1 Reply Latest reply on Jul 28, 2011 10:16 AM by Ned Murphy
    Calling MovieClips with if-else condition problem
    xiaoruiange Level 1
      Hi guys, I've a problem with calling the movieclip from the library with the if else case.
      If I take out the if else condition, the code runs normally but when I do I can't. I tried numerous attempts to fix the code but it still failed.
      What I wanted to do is, when I click one button out of 3 buttons at the 1st frame, it will pass the string (either red, blue or orange) to answer textbox. Then I store the string into a var called tarotno to go through a if else condition to call the MovieClip according to the string passed.
      The problem I'm facing now is whichever button I click, orangeMC will still be called.
      This is my code:
      import flash.display.MovieClip;
      var tarot:MovieClip;
      var tarotno = answer.text;
      if (tarotno == "red")
          tarot = new redMC();
      else if (tarotno == "blue")
          tarot = new blueMC();
      else if (tarotno == "orange")
          tarot = new orangeMC();
      else
      tarot.x = 396;
      tarot.y = 370;
      addChild(tarot);
      Thanks for your help in advance!!
