1 Reply Latest reply on Jul 29, 2011 12:35 AM by try67
    When do I (and don't I) use "this."?
    Sean McGilbert Level 1
      Whats the rule for using "this."?
      I see it regularly omitted from script samples. As in:
      getField('FancyName').display
      I would script the above as:
      this.getField('FancyName').display
      I use it all the time. Am I using it too much?
        • 1. Re: When do I (and don't I) use "this."?
          "this" can be omitted in all contexts when accessing its properties and
          methods (ie not when using it as a parameter in a function call, for
          example). If you're using it incorrectly, though, you will get an error
          whether you omitted it or not.
          It does no harm to use it and doesn't change the speed of the script, or
          anything like that. It can even make the code more readable.
          This is actually the reason why it's not a good idea to create variables or
          functions with identical names to those of the pre-defined objects. For
          example, if you try to define a variable called "path" in the console with a
          file opened in the background you'll get an error message: "redeclaration of
          const path", because the Document object already has such a property
          defined.
          If you close the file, then you could create your variable, but it will be
          overwritten as soon as a file is opened. Dangerous stuff...
