1 Reply Latest reply on Jul 29, 2011 12:48 PM by Rodrigo_Oliveira
    Using storeContentAPI method ocurr CSInvalidParameterException error.
    Rodrigo_Oliveira Level 1
      Hi all,
      I have a C# application that access DocumentManagementService web service. I'm tring to use the storeContentAPI, but a get the exception below:
      ALC-CSV-30106-000: com.adobe.livecycle.contentservices.client.exceptions.CSInvalidParameterException: ALC-CSV-030-106-No Content type specified while invoking [storeContent].; nested exception is:
      My code:
      Details:
      WebService URL: https://localhost:8443/soap/services/DirectoryManagerService?wsdl&lc_version=9.0.1
      Can you explain what is wrong?
      Thanks in advanced.
      Rodrigo
        • 1. Re: Using storeContentAPI method ocurr CSInvalidParameterException error.
          Sorry, my code below:
          DocumentManagementServiceService contentSpaceService = new DocumentManagementServiceService
        Credentials =
        new NetworkCredential(_username,
        _password)
                      string filename = Path.GetFileName(filePath);
                      //Create a BLOB object that PDF data
                      BLOB inData = new BLOB();
                      FileStream fs = new FileStream(filePath, FileMode.Open);
                      //Get the length of the file stream and create a byte array
                      int len = (int) fs.Length;
                      byte[] byteArray = new byte[len];
                      //Populate the byte array with the contents of the file stream
                      fs.Read(byteArray, 0, len);
                      //Populate the BLOB object
                      inData.binaryData = byteArray;
                      inData.MTOM = byteArray;
                      //Set the Description attribute
                      MyMapOf_xsd_string_To_xsd_anyType_Item desAttribute = new MyMapOf_xsd_string_To_xsd_anyType_Item
        key = "{http://www.alfresco.org/model/content/1.0}description",
        value = "File stored"
                      ////Set the creator attribute
                      MyMapOf_xsd_string_To_xsd_anyType_Item title = new MyMapOf_xsd_string_To_xsd_anyType_Item
        key = "{http://www.alfresco.org/model/content/1.0}title",
        value = filename
                      MyMapOf_xsd_string_To_xsd_anyType_Item nodeContentType = new MyMapOf_xsd_string_To_xsd_anyType_Item
        key = "{http://www.alfresco.org/model/content/1.0}node-type",
        value = "application/pdf"
                      //Set the items to the MyMapOf_xsd_string_To_xsd_anyType_Item instance
                      List<MyMapOf_xsd_string_To_xsd_anyType_Item> inputs = new List<MyMapOf_xsd_string_To_xsd_anyType_Item>
        desAttribute,
        title,
        nodeContentType
                      const string NODE_TYPE = "{http://www.alfresco.org/model/content/1.0}content";
                      const string NODE_ENCODING = "UTF-8";
                      string browseLink;
                      CRCResult crcResult;
                      contentSpaceService.storeContentAPI(CustomProperties.ContentService_StoreName,
                                                          CustomProperties.ContentSpace_ContentPath, filename,
                                                          NODE_TYPE, inData, NODE_ENCODING, UpdateVersionType.INCREMENT_MINOR_VERSION,
                                                          true, null, inputs.ToArray(), out browseLink, out crcResult);
