11 Replies Latest reply on Aug 2, 2011 12:11 PM by unique_screenname_here
    Pixel Bender custom multiply blend and other questions
    richard7854 Level 1
      I am creating photo editing application on iPad and i am using Pixel Bender to calculate effects. But ive got a problem with multiply blend mode.When i run it in CPU/GPU mode, it runs fine(result looks absolutly 1:1 as from photoshop). But when i switch to Flash Player mode, it dont want to render properly. I dont get any compilation errors. Ive got also some other questions:
      1.How does PB performs on iOS ?
      2.If my problem is becouse of  incapability of FP, is there any other solution to this ? I cant afford AS3.0 computing, becouse it is really slow even on PC.
      3. Can be Pixel Bender 3D sollution to this ? If yes, when will it come out to iOS ?
      4. How are filters computed in FP ? CPU or GPU ?
      here, you can see the difference : http://ponozka.php5.cz/gpuMode.jpg  http://ponozka.php5.cz/flashMode.jpg
      source code :
      <languageVersion : 1.0;>
      kernel MultiplyLayer
      <   namespace : "Your Namespace";
          vendor : "Richard Molnar";
          version : 1;
          input image4 src;
          input image4 layer;
          output pixel4 dst;
          parameter float4 param <
              minValue:float4(0.0,0.0,0.0,0.0);
              maxValue:float4(1.0,1.0,1.0,1.0);
              defaultValue:float4(1.0,1.0,1.0,1.0);
          void
          evaluatePixel()
              pixel4 pix;
              pixel4 pix2;
              pix = sampleNearest(src,outCoord());
              pix2 = sampleNearest(layer,outCoord());
              dst.r = pix.r - pix.r * (1.0-(pix2.r))*param.r*pix2.a*param.a;
              dst.g = pix.g- pix.g * (1.0-(pix2.g))*param.g*pix2.a*param.a;
              dst.b = pix.b -pix.b * (1.0-(pix2.b))*param.b*pix2.a*param.a;
              dst.a = 1.0;
