Dive into Adobe Summit 2024! Explore curated list of AEM sessions & labs, register, connect with experts, ask questions, engage, and share insights. Don't miss the excitement.
I've recently started testing LC suite...my query is suppose i've already deployed a service, and then later i'm asked to delete one node from the process work flow..and lets say at the given point the node has pending documents..so when i delete the node and re-deploy the service what happens to those pending documents? is there a way to handle this in LC rather than troubleshooting it by updating the values in the database..
If there are any process instances in progress then the process will be marked for deletion (meaning that no new processes will start with that process) and all new ones will use your new process. Anything that is in process will run against the old process. When the last process instance completes then and only then will your process be deleted.
