12 Replies Latest reply on Aug 21, 2011 4:22 AM by Eloise Friedman
    Flash Builder 4.5 (win7, 64 bit) frequently crashes
    Eloise Friedman
      Hi.
      I've upgraded my dev env to flash Builder 4.5.
      The IDE keeps crashing, even after increasing the jvm params to:
      jvm_args: -Xms512m -Xmx512m -XX:MaxPermSize=512m -XX:PermSize=128m
      The IDE can crash when I try to go to a class/method definition (F3), when I want to stop at a breakpoint, when navigating back to FB4.5 after using another application...
      It can happen every few minutes, not very productive!!!
      Can anyone offer any help?
      Thanks, Eloise.
        • 1. Re: Flash Builder 4.5 (win7, 64 bit) frequently crashes
          TucsonJava Level 1
          Did you make the jvm changes to eclipse.ini? Here is my eclipse.ini file and I do not have any real memory or crashing issues. (win7,64bit)
          -startup plugins/org.eclipse.equinox.launcher_1.1.1.R36x_v20101122_1400.jar
          --launcher.library plugins/org.eclipse.equinox.launcher.win32.win32.x86_1.1.2.R36x_v20101222
          -product org.eclipse.epp.package.jee.product
          --launcher.defaultAction openFile
          --launcher.XXMaxPermSize 256M
          -showsplash org.eclipse.platform
          -vmargs
          -XX:MaxPermSize=256m
          -XX:PermSize=64m
          -Dosgi.requiredJavaVersion=1.5
          -Xms40m
          -Xmx512m
          • 2. Re: Flash Builder 4.5 (win7, 64 bit) frequently crashes
            Eloise Friedman Level 1
            Thanks for your answer.
            do you use FB as a stand alone application or as eclipse plug-ins?
            I modified the FlashBuilder.ini file residing under "C:\Program Files (x86)\Adobe\Adobe Flash Builder 4.5", do you suggesst that I also modify the eclipse.ini file residing under "C:\Program Files (x86)\Adobe\Adobe Flash Builder 4.5\eclipse"?
            Thanks, Eloise.
            • 3. Re: Flash Builder 4.5 (win7, 64 bit) frequently crashes
              This is the content of ym eclipse.ini:
              -clean
              -startup
              plugins/org.eclipse.equinox.launcher_1.1.0.v20100507.jar
              --launcher.library
              plugins/org.eclipse.equinox.launcher.win32.win32.x86_1.1.1.R36x_v20100810
              -nl
              en_US
              -vmargs
              -Xms256m
              -Xmx512m
              -XX:PermSize=64m
              -Djava.net.preferIPv4Stack=true
              -Dorg.eclipse.equinox.p2.reconciler.dropins.directory=dropins
              -Declipse.application=com.adobe.flexbuilder.standalone.FlashBuilderApplication
              And this is the (modified) content of my FlashBuilder.ini:
              -startup
              eclipse/plugins/org.eclipse.equinox.launcher_1.1.0.v20100507.jar
              --launcher.library
              eclipse/plugins/org.eclipse.equinox.launcher.win32.win32.x86_1.1.1.R36x_v20100810
              openFile
              -nl
              en_US
              -vmargs
              -Xms512m
              -Xmx512m
              -XX:PermSize=128m
              -Dorg.eclipse.equinox.p2.reconciler.dropins.directory=eclipse/dropins
              Thanks, Eloise.
              • 4. Re: Flash Builder 4.5 (win7, 64 bit) frequently crashes
                TucsonJava Level 1
                I use the plug-in for eclipse. I expect that you modified the proper file for your environment (FlashBuilder.ini). Are you having any better luck with that configuration?
                • 5. Re: Flash Builder 4.5 (win7, 64 bit) frequently crashes
                  Yes, I modified the FlashBuilder.ini, to much higher values, and no luck :-(.
                  I think I will have to contact Adobe support, I can't work when the IDE crashes every few minutes...
                  • 6. Re: Flash Builder 4.5 (win7, 64 bit) frequently crashes
                    anirudhs Level 2
                    Can you post the contents of your log file? (workspacedir/.metadata/.log)
                    -Anirudh
                    • 7. Re: Flash Builder 4.5 (win7, 64 bit) frequently crashes
                      This is part of the log, if it doesn't help I can paste the entire content:
                      !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:07:52.024
                      !MESSAGE Problems occurred refreshing resources
                      !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:07:52.024
                      !MESSAGE Problem occurred in auto-refresh native code: 5.
                      !SESSION 2011-08-16 11:15:04.486 -----------------------------------------------
                      eclipse.buildId=I20100608-0911
                      java.version=1.6.0_16
                      java.vendor=Sun Microsystems Inc.
                      BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
                      Command-line arguments:  -os win32 -ws win32 -arch x86
                      !ENTRY org.eclipse.core.resources 2 10035 2011-08-16 11:15:05.685
                      !MESSAGE The workspace exited with unsaved changes in the previous session; refreshing workspace to recover changes.
                      !ENTRY org.eclipse.ui 2 0 2011-08-16 11:15:08.147
                      !MESSAGE Warnings while parsing the commands from the 'org.eclipse.ui.commands' and 'org.eclipse.ui.actionDefinitions' extension points.
                      !SUBENTRY 1 org.eclipse.ui 2 0 2011-08-16 11:15:08.147
                      !MESSAGE Commands should really have a category: plug-in='com.qnx.flashbuilder.multiplatform.qnx.ui', id='com.qnx.flashbuilder.multiplatform.qnx.ui.commands.OpenInfoCenter', categoryId='com.qnx.flashbuilder.multiplatform.qnx.ui.commands.category.help'
                      !ENTRY org.eclipse.jface 2 0 2011-08-16 11:15:22.389
                      !MESSAGE Keybinding conflicts occurred.  They may interfere with normal accelerator operation.
                      !SUBENTRY 1 org.eclipse.jface 2 0 2011-08-16 11:15:22.389
                      !MESSAGE A conflict occurred for CTRL+G:
                      Binding(CTRL+G,
                      ParameterizedCommand(Command(org.eclipse.jdt.ui.edit.text.java.search.declarations.in.wor kspace,Declaration in Workspace,
                        Search for declarations of the selected element in the workspace,
                        Category(org.eclipse.search.ui.category.search,Search,Search command category,true),
                        ,,true),null),
                      org.eclipse.ui.defaultAcceleratorConfiguration,
                      org.eclipse.ui.contexts.window,,,system)
                      Binding(CTRL+G,
                      ParameterizedCommand(Command(com.adobe.flexbuilder.as.editor.find.all.declarations.in.wor kspace,Find All Declarations In Workspace,
                        Category(com.adobe.flexbuilder.editorcore.navigation.category,Navigation,null,true),
                        LegacyHandlerWrapper(ActionHandler(action=com.adobe.flexbuilder.as.editor.ui.acti
                      This always appears after the IDE crashes:  Commands should really have a category: plug-in='com.qnx.flashbuilder.multiplatform.qnx.ui',
                      Thanks, Eloise.
                      • 8. Re: Flash Builder 4.5 (win7, 64 bit) frequently crashes
                        Anirudh Sasikumar Adobe Employee
                        That looks normal. Can you post the rest?
                        -Anirudh
                        • 9. Re: Flash Builder 4.5 (win7, 64 bit) frequently crashes
                          I hope I can paste such a long log...
                          !SESSION 2011-08-16 10:38:44.758 -----------------------------------------------
                          This is a continuation of log file C:\dev\replication\ui\workspace\.metadata\.bak_0.log
                          Created Time: 2011-08-16 10:53:06.235
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:06.236
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:06.236
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:07.287
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:07.287
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:08.338
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:08.338
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:09.346
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:09.346
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:10.397
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:10.397
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:11.449
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:11.449
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:12.501
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:12.501
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:13.552
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:13.552
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:14.603
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:14.603
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:15.655
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:15.655
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:16.706
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:16.706
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:17.758
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:17.758
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:18.810
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:18.810
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:19.861
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:19.861
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:20.913
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:20.913
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:21.964
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:21.964
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:23.015
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:23.015
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:24.066
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:24.066
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:25.118
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:25.118
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:26.170
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:26.170
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:27.222
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:27.222
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:28.274
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:28.274
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:29.326
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:29.326
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:30.378
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:30.378
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:31.432
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:31.432
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:32.484
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:32.484
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:33.816
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:33.816
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:34.868
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:34.868
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:35.925
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:35.925
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:36.977
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:36.977
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:38.030
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:38.030
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:39.081
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:39.081
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:40.133
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:40.133
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:41.186
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:41.186
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:42.237
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:42.237
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:43.289
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:43.289
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:44.341
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:44.341
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:45.393
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:45.393
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:46.444
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:46.444
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:47.496
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:47.496
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:48.548
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:48.548
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:49.601
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:49.601
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:50.653
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:50.653
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:51.704
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:51.704
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:52.755
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:52.755
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:53.797
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:53.797
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:54.806
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:54.806
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:55.821
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:55.821
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:56.859
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:56.859
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:57.908
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:57.908
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:53:58.960
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:53:58.960
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:00.011
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:00.011
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:01.062
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:01.062
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:02.114
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:02.114
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:03.166
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:03.166
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:04.218
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:04.218
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:05.269
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:05.269
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:06.321
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:06.321
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:07.376
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:07.376
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:08.428
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:08.428
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:09.480
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:09.480
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:10.532
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:10.532
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:11.583
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:11.583
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:12.635
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:12.635
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:13.687
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:13.687
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:14.738
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:14.738
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:15.790
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:15.790
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:16.842
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:16.842
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:17.894
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:17.894
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:18.946
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:18.946
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:19.997
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:19.997
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:21.049
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:21.049
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:22.101
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:22.101
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:23.153
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:23.153
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:24.204
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:24.204
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:25.256
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:25.256
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:26.261
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:26.261
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:27.313
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:27.313
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:28.365
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:28.365
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:29.420
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:29.420
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:30.472
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:30.472
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:31.527
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:31.527
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:32.579
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:32.579
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:33.947
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:33.947
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:34.999
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:34.999
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:36.051
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:36.051
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:37.103
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:37.103
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:38.155
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:38.155
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:39.206
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:39.206
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:40.258
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:40.258
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:41.310
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:41.310
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:42.361
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:42.361
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:43.413
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:43.413
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:44.465
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:44.465
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:45.517
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:45.517
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:46.569
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:46.569
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:47.621
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:47.621
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:48.673
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:48.673
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:49.725
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:49.725
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:50.777
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:50.777
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:51.829
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:51.829
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:52.881
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:52.881
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:53.933
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:53.933
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:54.985
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:54.985
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:56.037
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:56.037
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:57.088
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:57.088
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:58.140
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:58.140
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:54:59.154
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:54:59.154
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:00.206
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:00.206
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:01.258
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:01.258
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:02.309
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:02.309
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:03.368
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:03.368
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:04.420
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:04.420
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:05.471
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:05.471
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:06.523
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:06.523
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:07.574
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:07.574
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:08.626
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:08.626
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:09.678
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:09.678
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:10.730
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:10.730
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:11.781
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:11.781
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:12.833
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:12.833
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:13.885
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:13.885
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:14.936
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:14.936
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:15.987
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:15.987
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:17.039
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:17.039
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:18.093
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:18.093
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:19.096
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:19.096
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:20.148
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:20.148
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:21.199
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:21.199
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:22.250
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:22.250
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:23.302
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:23.302
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:24.332
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:24.332
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:25.359
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:25.359
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:30.011
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:30.011
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:31.063
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:31.063
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:32.115
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:32.115
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:33.167
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:33.167
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:34.219
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:34.219
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:35.223
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:35.223
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:36.275
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:36.275
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:37.327
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:37.327
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:38.379
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:38.379
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:39.432
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:39.432
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:40.487
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:40.487
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:41.538
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:41.538
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:42.590
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:42.590
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:43.642
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:43.642
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:44.694
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:44.694
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:45.767
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:45.767
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:46.819
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:46.819
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:47.871
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:47.871
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:48.923
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:48.923
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:49.974
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:49.974
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:51.026
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:51.026
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:52.040
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:52.040
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:53.061
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:53.061
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:54.113
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:54.113
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:55.165
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:55.165
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:56.209
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:56.209
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:57.261
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:57.261
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:58.281
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:58.282
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:55:59.333
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:55:59.333
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:00.381
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:00.381
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:02.631
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:02.631
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:03.683
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:03.683
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:04.734
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:04.734
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:05.786
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:05.786
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:06.837
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:06.837
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:07.888
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:07.888
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:08.940
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:08.940
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:09.992
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:09.992
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:11.044
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:11.044
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:12.095
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:12.095
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:13.147
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:13.147
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:14.198
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:14.198
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:15.249
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:15.249
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:16.301
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:16.301
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:17.310
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:17.310
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:20.762
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:20.762
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:21.795
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:21.795
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:22.847
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:22.847
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:23.898
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:23.898
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:24.903
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:24.903
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:25.954
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:25.954
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:27.106
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:27.106
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:28.158
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:28.158
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:29.200
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:29.200
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:30.252
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:30.252
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:31.303
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:31.303
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:32.354
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:32.354
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:33.405
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:33.405
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:34.456
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:34.456
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:35.507
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:35.507
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:36.558
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:36.558
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:37.609
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:37.609
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:38.660
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:38.660
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:39.712
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:39.712
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:40.764
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:40.764
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:41.816
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:41.816
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:42.867
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:42.867
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:43.919
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:43.919
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:44.971
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:44.971
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:46.064
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:46.064
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:47.115
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:47.115
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:48.167
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:48.167
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:49.219
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:49.219
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:50.260
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:50.260
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:51.801
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:51.801
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:52.853
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:52.853
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:53.907
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:53.907
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:54.959
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:54.959
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:56.010
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:56.010
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:57.062
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:57.062
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:58.114
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:58.114
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:56:59.165
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:56:59.165
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:00.181
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:00.181
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:01.191
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:01.191
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:05.342
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:05.342
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:06.374
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:06.374
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:07.426
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:07.426
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:08.478
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:08.478
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:09.529
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:09.529
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:10.581
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:10.581
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:11.633
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:11.633
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:12.684
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:12.684
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:13.740
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:13.740
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:14.792
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:14.792
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:15.910
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:15.910
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:16.961
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:16.961
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:18.013
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:18.013
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:19.065
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:19.065
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:20.117
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:20.117
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:21.169
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:21.169
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:22.221
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:22.221
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:23.272
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:23.272
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:24.324
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:24.324
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:25.381
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:25.381
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:26.386
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:26.386
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:27.438
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:27.438
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:28.490
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:28.490
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:29.532
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:29.532
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:30.583
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:30.583
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:31.610
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:31.610
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:32.662
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:32.662
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:33.713
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:33.713
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:34.765
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:34.765
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:35.817
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:35.817
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:36.869
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:36.869
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:37.921
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:37.921
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:38.973
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:38.973
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:39.979
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:39.979
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:41.030
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:41.030
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:42.071
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:42.071
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:43.725
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:43.725
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:44.748
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:44.748
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:45.804
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:45.804
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:46.855
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:46.855
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:57:47.924
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:57:47.924
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:18.317
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:18.317
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:19.372
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:19.372
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:21.443
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:21.443
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:22.495
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:22.495
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:23.546
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:23.546
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:24.597
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:24.597
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:25.623
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:25.623
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:26.674
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:26.674
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:27.729
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:27.729
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:28.781
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:28.781
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:29.850
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:29.850
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:30.904
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:30.904
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:31.956
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:31.956
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:33.007
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:33.007
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:34.058
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:34.058
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:35.110
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:35.110
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:36.161
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:36.161
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:37.213
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:37.213
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:38.264
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:38.264
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:39.316
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:39.316
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:40.368
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:40.368
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:41.373
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:41.373
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:42.425
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:42.425
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:43.476
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:43.476
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:44.528
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:44.528
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:45.580
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:45.580
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:46.632
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:46.632
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:47.683
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:47.683
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:48.685
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:48.685
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:49.736
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:49.736
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:50.788
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:50.788
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:51.839
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:51.839
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:52.841
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:52.841
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:53.892
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:53.892
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:54.943
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:54.943
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:55.994
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:55.994
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:57.046
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:57.046
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:58.097
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:58.097
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 10:59:59.148
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 10:59:59.148
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:00.199
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:00.199
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:01.252
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:01.252
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:02.304
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:02.304
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:03.359
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:03.359
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:04.373
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:04.373
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:05.440
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:05.440
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:06.491
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:06.491
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:07.542
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:07.542
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:08.594
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:08.594
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:09.645
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:09.645
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:10.647
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:10.647
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:11.698
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:11.698
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:12.750
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:12.750
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:13.801
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:13.801
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:14.852
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:14.852
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:15.903
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:15.903
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:16.955
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:16.955
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:18.006
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:18.006
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:19.057
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:19.057
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:20.109
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:20.109
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:21.161
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:21.161
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:22.212
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:22.212
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:23.264
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:23.264
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:24.315
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:24.315
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:25.371
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:25.371
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:26.389
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:26.389
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:27.452
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:27.452
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:28.504
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:28.504
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:29.558
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:29.558
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:30.609
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:30.609
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:31.684
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:31.684
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:32.736
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:32.736
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:33.803
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:33.803
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:34.854
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:34.854
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:35.905
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:35.905
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:36.956
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:36.956
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:38.008
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:38.008
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:39.087
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:39.087
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:40.139
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:40.139
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:41.190
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:41.190
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:42.227
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:42.227
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:43.278
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:43.278
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:44.329
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:44.329
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:45.527
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:45.527
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:46.579
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:46.579
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:47.630
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:47.630
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:48.682
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:48.682
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:49.708
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:49.708
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:50.760
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:50.760
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:51.811
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:51.811
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:52.862
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:52.862
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:53.913
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:53.913
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:54.965
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:54.965
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:56.016
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:56.016
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:57.067
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:57.067
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:58.118
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:58.118
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:00:59.153
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:00:59.153
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:00.204
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:00.204
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:01.255
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:01.255
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:02.306
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:02.306
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:03.346
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:03.346
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:04.367
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:04.367
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:05.422
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:05.422
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:06.443
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:06.444
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:07.498
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:07.498
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:08.549
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:08.549
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:09.619
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:09.619
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:10.634
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:10.634
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:11.689
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:11.689
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:12.741
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:12.741
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:13.796
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:13.796
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:14.847
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:14.847
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:15.899
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:15.899
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:16.950
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:16.950
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:18.002
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:18.002
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:19.053
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:19.053
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:20.104
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:20.104
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:21.155
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:21.155
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:22.207
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:22.207
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:23.258
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:23.258
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:24.312
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:24.312
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:25.364
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:25.364
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:26.416
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:26.416
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:27.468
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:27.468
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:28.520
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:28.520
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:29.571
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:29.571
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:30.623
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:30.623
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:31.636
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:31.636
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:32.688
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:32.688
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:33.693
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:33.693
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:34.745
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:34.745
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:35.796
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:35.796
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:36.848
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:36.848
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:37.900
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:37.900
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:38.951
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:38.951
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:40.002
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:40.002
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:41.053
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:41.053
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:42.086
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:42.086
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:43.138
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:43.138
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:44.189
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:44.189
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:45.241
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:45.241
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:46.292
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:46.292
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:47.346
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:47.346
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:48.349
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:48.349
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:49.404
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:49.404
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:50.455
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:50.455
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:51.510
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:51.510
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:52.562
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:52.562
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:53.617
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:53.617
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:54.669
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:54.669
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:55.724
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:55.724
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:56.776
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:56.776
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:57.867
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:57.867
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:58.919
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:58.919
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:01:59.970
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:01:59.970
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:01.021
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:01.021
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:02.072
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:02.072
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:03.123
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:03.123
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:04.174
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:04.174
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:05.225
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:05.225
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:06.277
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:06.277
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:07.333
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:07.333
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:08.377
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:08.377
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:09.429
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:09.429
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:10.480
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:10.480
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:11.496
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:11.496
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:12.548
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:12.548
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:13.599
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:13.599
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:14.650
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:14.650
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:15.701
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:15.701
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:16.752
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:16.752
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:17.803
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:17.803
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:18.854
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:18.854
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:19.863
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:19.863
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:20.877
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:20.877
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:21.928
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:21.928
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:22.979
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:22.979
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:24.031
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:24.031
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:25.082
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:25.082
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:26.133
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:26.133
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:27.185
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:27.185
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:28.236
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:28.236
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:29.288
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:29.288
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:30.346
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:30.346
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:31.399
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:31.399
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:32.448
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:32.448
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:33.515
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:33.515
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:34.622
                          !MESSAGE Problems occurred refreshing resources
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:34.622
                          !MESSAGE Problem occurred in auto-refresh native code: 5.
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:36.408
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:36.408
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:38.049
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:38.049
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:39.101
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:39.101
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:40.167
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:40.167
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:41.231
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:41.231
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:42.296
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:42.296
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:43.389
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:43.389
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:44.457
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:44.457
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:45.524
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:45.524
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:46.576
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:46.576
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:47.628
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:47.628
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:48.693
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:48.693
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:49.759
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:49.759
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:50.811
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:50.811
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:51.863
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:51.863
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:52.870
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:52.870
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:53.922
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:53.922
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:54.974
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:54.974
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:56.026
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:56.026
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:02:57.381
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:02:57.381
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:03:06.743
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:03:06.743
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:03:16.095
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:03:16.095
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:03:25.691
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:03:25.691
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:03:35.059
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:03:35.059
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:03:44.362
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:03:44.362
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:03:53.713
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:03:53.713
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:04:02.892
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:04:02.892
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:04:04.534
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:04:04.534
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:04:05.592
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:04:05.592
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:04:06.658
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:04:06.658
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:04:07.737
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:04:07.737
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:04:08.798
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:04:08.798
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:04:09.873
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:04:09.873
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:04:10.980
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:04:10.980
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:04:12.651
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:04:12.651
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:04:13.719
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:04:13.719
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:04:14.731
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:04:14.731
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:04:15.797
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:04:15.798
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:04:17.149
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:04:17.149
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:04:26.500
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:04:26.500
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:04:35.852
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:04:35.852
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:04:45.219
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:04:45.219
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:04:54.571
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:04:54.571
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:05:03.922
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:05:03.922
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:05:13.242
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:05:13.242
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:05:22.307
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:05:22.307
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:05:23.658
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:05:23.658
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:05:32.773
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:05:32.773
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:05:33.825
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:05:33.825
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:05:34.891
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:05:34.891
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:05:35.956
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:05:35.956
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:05:37.058
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:05:37.058
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:05:38.609
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:05:38.609
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:05:39.678
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:05:39.678
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:05:41.029
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:05:41.029
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:05:50.380
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:05:50.380
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:05:59.732
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:05:59.732
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:06:09.102
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:06:09.102
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:06:18.460
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:06:18.460
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:06:27.812
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:06:27.812
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:06:37.184
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:06:37.184
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:06:46.535
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:06:46.535
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:06:55.886
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:06:55.886
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:07:05.249
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:07:05.249
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:07:14.600
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:07:14.600
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:07:33.301
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:07:33.301
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:07:42.673
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:07:42.673
                          !ENTRY org.eclipse.core.resources 4 1 2011-08-16 11:07:52.024
                          !SUBENTRY 1 org.eclipse.core.resources 4 1 2011-08-16 11:07:52.024
                          !SESSION 2011-08-16 11:15:04.486 -----------------------------------------------
                          eclipse.buildId=I20100608-0911
                          java.version=1.6.0_16
                          java.vendor=Sun Microsystems Inc.
                          BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
                          Command-line arguments:  -os win32 -ws win32 -arch x86
                          !ENTRY org.eclipse.core.resources 2 10035 2011-08-16 11:15:05.685
                          !MESSAGE The workspace exited with unsaved changes in the previous session; refreshing workspace to recover changes.
                          !ENTRY org.eclipse.ui 2 0 2011-08-16 11:15:08.147
                          !MESSAGE Warnings while parsing the commands from the 'org.eclipse.ui.commands' and 'org.eclipse.ui.actionDefinitions' extension points.
                          !SUBENTRY 1 org.eclipse.ui 2 0 2011-08-16 11:15:08.147
                          !MESSAGE Commands should really have a category: plug-in='com.qnx.flashbuilder.multiplatform.qnx.ui', id='com.qnx.flashbuilder.multiplatform.qnx.ui.commands.OpenInfoCenter', categoryId='com.qnx.flashbuilder.multiplatform.qnx.ui.commands.category.help'
                          !ENTRY org.eclipse.jface 2 0 2011-08-16 11:15:22.389
                          !MESSAGE Keybinding conflicts occurred.  They may interfere with normal accelerator operation.
                          !SUBENTRY 1 org.eclipse.jface 2 0 2011-08-16 11:15:22.389
                          !MESSAGE A conflict occurred for CTRL+G:
                          Binding(CTRL+G,
                          ParameterizedCommand(Command(org.eclipse.jdt.ui.edit.text.java.search.declarations.in.wor kspace,Declaration in Workspace,
                            Search for declarations of the selected element in the workspace,
                            Category(org.eclipse.search.ui.category.search,Search,Search command category,true),
                            ,,true),null),
                          org.eclipse.ui.defaultAcceleratorConfiguration,
                          org.eclipse.ui.contexts.window,,,system)
                          Binding(CTRL+G,
                          ParameterizedCommand(Command(com.adobe.flexbuilder.as.editor.find.all.declarations.in.wor kspace,Find All Declarations In Workspace,
                            Category(com.adobe.flexbuilder.editorcore.navigation.category,Navigation,null,true),
                            LegacyHandlerWrapper(ActionHandler(action=com.adobe.flexbuilder.as.editor.ui.actions.FindAllDeclarationsAction@12d6d82)),
                            ,,true),null),
                          com.adobe.flexide.editorcore.flexEditorScope,,,system)
                          Binding(CTRL+G,
                            ,,true),null),
                          com.adobe.flexbuilder.as.editor.context.packageexplorer,,,system)
                          !MESSAGE A conflict occurred for CTRL+SHIFT+G:
                          Binding(CTRL+SHIFT+G,
                          ParameterizedCommand(Command(org.eclipse.jdt.ui.edit.text.java.search.references.in.works pace,References in Workspace,
                            Search for references to the selected element in the workspace,
                            ,,true),null),
                          ParameterizedCommand(Command(com.adobe.flexbuilder.as.editor.find.all.references.in.works pace,Find All References In Workspace,
                            LegacyHandlerWrapper(ActionHandler(action=com.adobe.flexbuilder.as.editor.ui.actions.FindAllReferencesAction@170736f)),
                            ,,true),null),
                            ,,true),null),
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:15:25.455
                          !MESSAGE Unsupported design description file libs/tink_flex4_spark.swc
                             root tag: expected = design, actual = design
                             version: expected = 2, actual =
                          !STACK 0
                          java.lang.Exception
                          at com.adobe.flexbuilder.project.internal.FlexProjectCore.createErrorStatus(FlexProjectCore. java:1010)
                          at com.adobe.flexbuilder.util.logging.GlobalLogImpl.log(GlobalLogImpl.java:66)
                          at com.adobe.flexbuilder.util.logging.GlobalLog.log(GlobalLog.java:52)
                          at com.adobe.flexide.designitems.types.DesignExtensions.buildTree(DesignExtensions.java:106)
                          at com.adobe.flexide.designitems.types.DesignExtensions.<init>(DesignExtensions.java:74)
                          at com.adobe.flexide.designitems.types.DesignTypeRegistry.<init>(DesignTypeRegistry.java:61)
                          at com.adobe.flexbuilder.mxml.editor.design.internal.MXMLDesignView4Controller.<init>(MXMLDe signView4Controller.java:216)
                          at com.adobe.flexbuilder.mxml.editor.design.MXMLDesignViewFactory.createController(MXMLDesig nViewFactory.java:42)
                          at com.adobe.flexbuilder.mxml.editor.design.MXMLDesignEditor.initDesignView(MXMLDesignEditor .java:1793)
                          at com.adobe.flexbuilder.mxml.editor.design.MXMLDesignEditor.initializeDesignView(MXMLDesign Editor.java:1713)
                          at com.adobe.flexbuilder.mxml.editor.design.MXMLDesignEditor.initializeDesignView(MXMLDesign Editor.java:1730)
                          at com.adobe.flexbuilder.mxml.editor.design.MXMLDesignEditor.embeddedAssetCompilationOver(MX MLDesignEditor.java:2736)
                          at com.adobe.flexbuilder.mxml.editor.design.MXMLDesignEditor.assetCompilationCompleted(MXMLD esignEditor.java:4002)
                          at com.adobe.flexide.editorcore.dvswfbuilder.EmbeddedAssetsSWFBuilder$3.run(EmbeddedAssetsSW FBuilder.java:1126)
                          at org.eclipse.swt.widgets.Display.runTimer(Display.java:4167)
                          at org.eclipse.swt.widgets.Display.messageProc(Display.java:3256)
                          at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
                          at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:2459)
                          at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3655)
                          at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2640)
                          at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
                          at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
                          at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
                          at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
                          at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
                          at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
                          at com.adobe.flexbuilder.standalone.FlashBuilderApplication.start(FlashBuilderApplication.ja va:108)
                          at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
                          at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLau ncher.java:110)
                          at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.jav a:79)
                          at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
                          at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
                          at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
                          at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
                          at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
                          at java.lang.reflect.Method.invoke(Unknown Source)
                          at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
                          at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
                          at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
                          !ENTRY com.adobe.flexide.designitems 4 1 2011-08-16 11:15:29.541
                          !MESSAGE Design view: Failed to load library.swf from C:\dev\replication\ui\attunity.replication.views\libs\visualizer.swc, reason=DesignAssetLoader.CompleteTimeout
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:15:29.779
                          !STACK 0
                          java.lang.Exception
                          at com.adobe.flexbuilder.mxml.editor.design.internal.MXMLDesignView4Controller$LoaderListene r$1.run(MXMLDesignView4Controller.java:1105)
                          at com.adobe.flexbuilder.mxml.editor.design.internal.MXMLDesignView4Controller$6.run(MXMLDes ignView4Controller.java:2774)
                          at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
                          at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:134)
                          at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4041)
                          at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3660)
                          !ENTRY com.adobe.flexide.designitems 4 1 2011-08-16 11:15:33.202
                          !MESSAGE Design view: Failed to load library.swf from C:\dev\replication\ui\attunity.replication.views\libs\diagrammer.swc, reason=DesignAssetLoader.CompleteTimeout
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:15:33.439
                          !STACK 0
                          java.lang.Exception
                          !ENTRY com.adobe.flexide.designitems 4 1 2011-08-16 11:15:37.867
                          !MESSAGE Design view: Failed to load library.swf from C:\dev\replication\ui\attunity.replication.views\libs\visualizerMultitouch.swc, reason=DesignAssetLoader.CompleteTimeout
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:15:38.093
                          !STACK 0
                          java.lang.Exception
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:15:39.678
                          !MESSAGE Error loading ClassReference for attunity.replication.views.skins.DefaultTitleWindowSkin
                          !STACK 0
                          java.lang.Exception
                          at com.adobe.flexbuilder.project.internal.FlexProjectCore.log(FlexProjectCore.java:858)
                          at com.adobe.flexbuilder.util.logging.GlobalLogImpl.log(GlobalLogImpl.java:56)
                          at com.adobe.flexbuilder.util.logging.GlobalLog.log(GlobalLog.java:41)
                          at com.adobe.flexbuilder.mxml.editor.design.internal.MXMLDesignView4Controller$DesignViewCal lbacks.reportInternalError(MXMLDesignView4Controller.java:603)
                          at com.adobe.flexide.playerview.DesignCall.invoke(DesignCall.java:96)
                          at com.adobe.flexide.playerview.PlayerListenerHost.notifyDesignCall(PlayerListenerHost.java: 173)
                          at com.adobe.flexide.playerview.PlayerListenerHost.callFunction(PlayerListenerHost.java:47)
                          at com.adobe.flexide.embeddedplayer.PlayerNativeCallbacks.CallJavaFunction(PlayerNativeCallb acks.java:48)
                          at com.adobe.flexide.embeddedplayer.PlayerNatives.CallActionScript(Native Method)
                          at com.adobe.flexide.embeddedplayer.ExternalPlayer.callFunction2(ExternalPlayer.java:94)
                          at com.adobe.flexide.playerview.PlayerCaller.callFunction(PlayerCaller.java:73)
                          at com.adobe.flexide.playerview.PlayerCaller.callFunctionNoResult(PlayerCaller.java:44)
                          at com.adobe.flexide.designitems.styles.DesignStylist.applyStyles(DesignStylist.java:267)
                          at com.adobe.flexide.designitems.styles.DesignStylist.refreshStyles(DesignStylist.java:226)
                          at com.adobe.flexide.designitems.styles.DesignStylist.updateStyles(DesignStylist.java:196)
                          at com.adobe.flexide.designitems.surface.DesignSurface.visitModel(DesignSurface.java:1014)
                          at com.adobe.flexide.designitems.surface.DesignSurface.install(DesignSurface.java:236)
                          at com.adobe.flexbuilder.mxml.editor.design.internal.MXMLDesignView4Controller.finishDesignS urfaceInstall(MXMLDesignView4Controller.java:437)
                          at com.adobe.flexbuilder.mxml.editor.design.internal.MXMLDesignView4Controller.access$21(MXM LDesignView4Controller.java:433)
                          at com.adobe.flexbuilder.mxml.editor.design.internal.MXMLDesignView4Controller$1.notifyAllSw fsLoaded(MXMLDesignView4Controller.java:416)
                          at com.adobe.flexide.designitems.surface.FXGComponentManager.notifyAllSwfsLoaded(FXGComponen tManager.java:570)
                          at com.adobe.flexide.designitems.surface.FXGComponentManager.loadAllSWFs(FXGComponentManager .java:557)
                          at com.adobe.flexide.designitems.surface.FXGComponentManager.scanModel(FXGComponentManager.j ava:505)
                          at com.adobe.flexbuilder.mxml.editor.design.internal.MXMLDesignView4Controller.installDesign Surface(MXMLDesignView4Controller.java:421)
                          at com.adobe.flexbuilder.mxml.editor.design.internal.MXMLDesignView4Controller.runtimeStyles Loaded(MXMLDesignView4Controller.java:1781)
                          at com.adobe.flexbuilder.mxml.editor.design.internal.MXMLDesignView4Controller.loadRuntimeSt yleDeclarations(MXMLDesignView4Controller.java:1204)
                          at com.adobe.flexbuilder.mxml.editor.design.internal.MXMLDesignView4Controller.embeddedAsset sSwfLoaded(MXMLDesignView4Controller.java:1762)
                          at com.adobe.flexbuilder.mxml.editor.design.internal.MXMLDesignView4Controller.continueWithE mbeddedAssetLoading(MXMLDesignView4Controller.java:1740)
                          at com.adobe.flexbuilder.mxml.editor.design.internal.MXMLDesignView4Controller.libraryPathSw fsLoaded(MXMLDesignView4Controller.java:1643)
                          at com.adobe.flexbuilder.mxml.editor.design.internal.MXMLDesignView4Controller$LoaderListene r.loadComplete(MXMLDesignView4Controller.java:1084)
                          at com.adobe.flexide.designitems.loaders.LibrarySWCLoader.loadNextSWF(LibrarySWCLoader.java: 93)
                          at com.adobe.flexide.designitems.loaders.LibrarySWCLoader.access$5(LibrarySWCLoader.java:89)
                          at com.adobe.flexide.designitems.loaders.LibrarySWCLoader$SwcLoaderCallbacks.SWFLoaded(Libra rySWCLoader.java:156)
                          at sun.reflect.GeneratedMethodAccessor41.invoke(Unknown Source)
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:15:39.681
                          !STACK 0
                          java.lang.Exception
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:15:39.709
                          !MESSAGE Error loading ClassReference for attunity.replication.views.skins.DefaultListSkin
                          !STACK 0
                          java.lang.Exception
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:20:05.216
                          !STACK 0
                          java.lang.Exception
                          at com.adobe.flexbuilder.mxml.editor.design.MXMLDesignEditor.initializeDesignViewFromCodeVie w(MXMLDesignEditor.java:3900)
                          at com.adobe.flexbuilder.mxml.editor.MXMLEditor$6.run(MXMLEditor.java:1366)
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:20:06.826
                          !STACK 0
                          java.lang.Exception
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:20:06.830
                          !STACK 0
                          java.lang.Exception
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:20:06.858
                          !STACK 0
                          java.lang.Exception
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:27:23.208
                          !STACK 0
                          java.lang.Exception
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:27:24.868
                          !STACK 0
                          java.lang.Exception
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:27:24.871
                          !STACK 0
                          java.lang.Exception
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:27:24.898
                          !STACK 0
                          java.lang.Exception
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:28:13.624
                          !STACK 0
                          java.lang.Exception
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:28:15.201
                          !STACK 0
                          java.lang.Exception
                          at sun.reflect.GeneratedMethodAccessor55.invoke(Unknown Source)
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:28:15.204
                          !STACK 0
                          java.lang.Exception
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:28:15.231
                          !STACK 0
                          java.lang.Exception
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:28:15.942
                          !MESSAGE StyleModelManager.setDocumentModel called when document model already set
                          !STACK 0
                          java.lang.Exception
                          at com.adobe.flexide.designitems.styles.StyleModelManager.setDocumentModel(StyleModelManager .java:102)
                          at com.adobe.flexide.designitems.styles.DesignStylist.setDocumentModel(DesignStylist.java:10 7)
                          at com.adobe.flexbuilder.mxml.editor.design.internal.MXMLDesignView4Controller.createDesignS urface(MXMLDesignView4Controller.java:384)
                          at com.adobe.flexbuilder.mxml.editor.design.internal.MXMLDesignView4Controller.installDesign Surface(MXMLDesignView4Controller.java:404)
                          at com.adobe.flexbuilder.mxml.editor.design.internal.MXMLDesignView4Controller.assetCompilat ionOver(MXMLDesignView4Controller.java:1669)
                          at com.adobe.flexbuilder.mxml.editor.design.MXMLDesignEditor.sendAssetCompilationCompletedIn foToController(MXMLDesignEditor.java:4031)
                          at com.adobe.flexbuilder.mxml.editor.design.MXMLDesignEditor.sendCompilationSatausToControll er(MXMLDesignEditor.java:4046)
                          at com.adobe.flexbuilder.mxml.editor.design.MXMLDesignEditor.createEmbeddedAssetBuilder(MXML DesignEditor.java:1962)
                          at com.adobe.flexbuilder.mxml.editor.design.MXMLDesignEditor.access$19(MXMLDesignEditor.java :1945)
                          at com.adobe.flexbuilder.mxml.editor.design.MXMLDesignEditor$4.run(MXMLDesignEditor.java:266 1)
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:28:15.961
                          !MESSAGE StyleModelManager.setBaseDocumentModel called when base document model already set
                          !STACK 0
                          java.lang.Exception
                          at com.adobe.flexide.designitems.styles.StyleModelManager.setBaseDocumentModel(StyleModelMan ager.java:84)
                          at com.adobe.flexide.designitems.styles.DesignStylist.setBaseDocumentModel(DesignStylist.jav a:115)
                          at com.adobe.flexide.designitems.surface.DesignSurface.applyMainAppStyles(DesignSurface.java :1028)
                          at com.adobe.flexide.designitems.surface.DesignSurface.visitModel(DesignSurface.java:1012)
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:28:16.467
                          !STACK 0
                          java.lang.Exception
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:28:18.136
                          !STACK 0
                          java.lang.Exception
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:28:18.139
                          !STACK 0
                          java.lang.Exception
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:28:18.167
                          !STACK 0
                          java.lang.Exception
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:28:21.608
                          !STACK 0
                          java.lang.Exception
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:28:23.265
                          !STACK 0
                          java.lang.Exception
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:28:23.268
                          !STACK 0
                          java.lang.Exception
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:28:23.295
                          !STACK 0
                          java.lang.Exception
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:28:30.688
                          !STACK 0
                          java.lang.Exception
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:28:32.291
                          !STACK 0
                          java.lang.Exception
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:28:32.293
                          !STACK 0
                          java.lang.Exception
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:28:32.321
                          !STACK 0
                          java.lang.Exception
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:28:33.174
                          !STACK 0
                          java.lang.Exception
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:28:33.194
                          !STACK 0
                          java.lang.Exception
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:28:33.732
                          !STACK 0
                          java.lang.Exception
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:28:35.275
                          !STACK 0
                          java.lang.Exception
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:28:35.278
                          !STACK 0
                          java.lang.Exception
                          at sun.reflect.GeneratedMethodAccessor57.invoke(Unknown Source)
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:28:35.305
                          !STACK 0
                          java.lang.Exception
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:43:23.270
                          !STACK 0
                          java.lang.Exception
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:43:24.824
                          !STACK 0
                          java.lang.Exception
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:43:24.827
                          !STACK 0
                          java.lang.Exception
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 11:43:24.855
                          !STACK 0
                          java.lang.Exception
                          !SESSION 2011-08-16 12:09:27.189 -----------------------------------------------
                          !ENTRY org.eclipse.core.resources 2 10035 2011-08-16 12:09:28.399
                          !ENTRY org.eclipse.ui 2 0 2011-08-16 12:09:30.993
                          !SUBENTRY 1 org.eclipse.ui 2 0 2011-08-16 12:09:30.993
                          !ENTRY org.eclipse.jface 2 0 2011-08-16 12:09:45.710
                          !SUBENTRY 1 org.eclipse.jface 2 0 2011-08-16 12:09:45.710
                          Binding(CTRL+G,
                            ,,true),null),
                          Binding(CTRL+G,
                            LegacyHandlerWrapper(ActionHandler(action=com.adobe.flexbuilder.as.editor.ui.actions.FindAllDeclarationsAction@149e05d)),
                            ,,true),null),
                          Binding(CTRL+G,
                            ,,true),null),
                            ,,true),null),
                            LegacyHandlerWrapper(ActionHandler(action=com.adobe.flexbuilder.as.editor.ui.actions.FindAllReferencesAction@ddf639)),
                            ,,true),null),
                            ,,true),null),
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 12:09:46.980
                          !STACK 0
                          java.lang.Exception
                          !ENTRY com.adobe.flexide.designitems 4 1 2011-08-16 12:09:51.238
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 12:09:51.472
                          !STACK 0
                          java.lang.Exception
                          !ENTRY com.adobe.flexide.designitems 4 1 2011-08-16 12:09:54.852
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 12:09:55.080
                          !STACK 0
                          java.lang.Exception
                          !ENTRY com.adobe.flexide.designitems 4 1 2011-08-16 12:09:58.611
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 12:09:58.843
                          !STACK 0
                          java.lang.Exception
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 12:10:00.423
                          !STACK 0
                          java.lang.Exception
                          at sun.reflect.GeneratedMethodAccessor40.invoke(Unknown Source)
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 12:10:00.427
                          !STACK 0
                          java.lang.Exception
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 12:10:00.455
                          !STACK 0
                          java.lang.Exception
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 12:11:23.388
                          !STACK 0
                          java.lang.Exception
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 12:11:25.079
                          !STACK 0
                          java.lang.Exception
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 12:11:25.085
                          !STACK 0
                          java.lang.Exception
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 12:11:25.112
                          !STACK 0
                          java.lang.Exception
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 12:11:26.130
                          !STACK 0
                          java.lang.Exception
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 12:11:26.159
                          !STACK 0
                          java.lang.Exception
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 12:11:26.744
                          !STACK 0
                          java.lang.Exception
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 12:11:28.339
                          !STACK 0
                          java.lang.Exception
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 12:11:28.342
                          !STACK 0
                          java.lang.Exception
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 12:11:28.370
                          !STACK 0
                          java.lang.Exception
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 12:13:13.423
                          !STACK 0
                          java.lang.Exception
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 12:13:15.005
                          !STACK 0
                          java.lang.Exception
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 12:13:15.008
                          !STACK 0
                          java.lang.Exception
                          !ENTRY com.adobe.flexbuilder.project 4 43 2011-08-16 12:13:15.037
                          !STACK 0
                          java.lang.Exception
                          Thanks, Eloise.
                          • 10. Re: Flash Builder 4.5 (win7, 64 bit) frequently crashes
                            Anirudh Sasikumar Adobe Employee
                            Okay, the log indicates that design view has trouble loading your skins.
                            Can you try disabling design view to see if it crashes? (Uncheck Window menu -> Enable Design mode)
                            -Anirudh
                            • 11. Re: Flash Builder 4.5 (win7, 64 bit) frequently crashes
                              Eloise Friedman Level 1
                              I unchecked the option, and will update you in a few hours if the editor is more stable.
                              Thanks, Eloise.
                              • 12. Re: Flash Builder 4.5 (win7, 64 bit) frequently crashes
                                This seems to have solved the problem, thanks, Eloise.
