4 Replies Latest reply on Aug 2, 2011 12:05 AM by zhanglog
    TileList dataProvider problem
    Benoitcn Level 1
      I use removeAll function to clean the dataProvider then I additem to it.
      There is an error occured. Because the dataProvider is null !
      So I recreate the dataProvider the error still there Why ~~?
      this is the code:
      var i:int = 0;
         if( TileList.dataProvider )
          TileList.dataProvider.removeAll(); // I remove all items.
         else{  // next time I try to recreate it but I still can't add item to the dataprovider
           // TileList.dataProvider.addItem("Class 1"); I can't do it because the dataprovider is null now
          TileList.dataProvider = new ListCollectionView( );
          while( i++ < 15 ){
           TileList.dataProvider.addItem("Class" + i);
        • 1. Re: TileList dataProvider problem
          Pooja Kuber Level 2
          Try to use
           TileList.dataProvider = new ArrayCollection( );
          in else part, instead of
          Also make a note that the if statement will always return true even if you remove all the elements. That will just remove the data from dataprovider making its length to 0. Instead you can check the if the length of dataprovider is greater than 0.
          if( contentList.dataProvider.length > 0 )
          Thanks and Regards,
          Pooja Kuber | pkuber@infocepts.com | www.infocepts.com
          • 2. Re: TileList dataProvider problem
            Benoitcn Level 1
            I really confuse Why the dataProvider become null after removed all items ??
            • 3. Re: TileList dataProvider problem
              Pooja Kuber Level 2
              Hmm.. It seems that the data provider is not getting instanciated, which is resulating into null object reference error. I tried out the following code.
              <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"
                              layout="absolute">
                  <mx:Script>
                      <![CDATA[
                          import flash.text.engine.ContentElement;
                          import mx.collections.ArrayCollection;
                          public function btnClick():void
                              var i:int=0;
                              if (contentList.dataProvider.length > 0)
                                  contentList.dataProvider.removeAll();
                              else
                                  contentList.dataProvider=new ArrayCollection();
                                  while (i++ < 15)
                                      contentList.dataProvider.addItem("Class" + i);
                  </mx:Script>
                  <mx:Canvas width="100%"
                             height="100%">
                      <mx:TileList id="contentList"
                                   visible="true"
                                   width="50%"
                                   height="50%"
                                   horizontalCenter="0"
                                   bottom="10"
                                   horizontalScrollPolicy="off"
                                   verticalScrollPolicy="off"
                                   verticalAlign="middle"
                                   maxColumns="3"
                                   maxRows="5"
                                   rowHeight="{contentList.height*0.20}"
                                   columnWidth="{contentList.width*0.33}"
                                   dataProvider="{new ArrayCollection()}">
                      </mx:TileList>
                      <mx:Button id="btn"
                                 label="Populate Tile List"
                                 width="{btn.label.length * 8}"
                                 height="20"
                                 click="btnClick()">
                      </mx:Button>
                  </mx:Canvas>
              </mx:Application>
              May be this will help you.
              Thanks and Regards,
              • 4. Re: TileList dataProvider problem
                zhanglog Level 1
                before your code
                you did not set any value to dataProvider,so dataProvider is null,
                and you code
                never work,because
                is false
