3 Replies Latest reply on Nov 8, 2006 11:20 AM by Rnrent
    Animations With Images
    Rnrent
      I've recently started using Fireworks 8, and I have a problem animating.
      I tried to animate some text on an image, but it didn't entirely work. The animated text itself works, but the image the text is on just blinks in for a second. How do I make the image stay for the whole animation?
        • 1. Re: Animations With Images
          Level 7
          Rnrent,
          Select the image you want to copy and in the Frames Panel Options tab
          choose 'Copy to Frames'.
          alex
          • 2. Re: Animations With Images
            paul_Mas
            If your image is on the separate layer you can also click the 'Share This Layer' from the Layers Panel option tab to work through your animation.
            • 3. Re: Animations With Images
              Rnrent Level 1
              Thank you, it worked.
              quote:
              Originally posted by: Newsgroup User
              Rnrent,
              alex
