1 Reply Latest reply on Aug 2, 2011 2:44 AM by david_a_clark
    CSAWIDEXPORTER problem
    sameer kariwala
      Hi Friends,
      I am having problem in generating SWC file using CSAWIDEXPORTER Library.
      I have successfully compiled Csawidexporter with no warning.
      I am not generating SWC file when mock balaned is unchecked.
      I am getting till moack balanced is checked as mention in getting-started-with-csawidexporter.pdf.
      I debugged into code i found out it is throwing exception in
      AppController.as file at
      (!model.mockBackend)
      var unapp:Object = InDesign.app as Object;
      // Windows at least, the trailing File.separator is needed
      unapp.dommygeneratecode(model.templateFileAsString, computedSrcPath.nativePath + File.separator);
      it is throwing exception at
      Please help on this, i will be highly obliged for any answer.
      sameer
      if
      generate() in
