2 Replies Latest reply on Aug 2, 2011 2:06 PM by Danny Noonan
    [CS5] [JS]-Gradient Feather with Gradient Stops Question
    Danny Noonan Level 1
      Hello,
      Have any of you ever scripted applying a Gradient Feather with Opacity Gradient Stops. If so, I would appreciate you assistance. I'm trying to apply multiple effects to objects. I can apply the gradient feather but I am having issues with the stops.
      //Inner Glow settings from milligramme
      var obj=app.activeDocument.selection[0];
      $.writeln(obj.transparencySettings.innerGlowSettings.properties.toSource().replace(/,/g,",\n"));
      with (obj.transparencySettings.innerGlowSettings){
        applied = true;
        blendMode = 1852797549/*BlendMode.NORMAL*/;
        opacity = 100;
        noise = 0;
        effectColor = "Paper";
        technique = 2020618338/*GlowTechnique.PRECISE*/;
        spread = 79;
        size = '0.125in';
        source = 2020618594 /*InnerGlowSource.EDGE_SOURCED*/;
       //Directional Feather settings, based off milligrammes script
      $.writeln(obj.transparencySettings.directionalFeatherSettings.properties.toSource().replace(/,/g,",\n"));
      with (obj.transparencySettings.directionalFeatherSettings){
        applied = true;
        angle = 46;
        noise = 0;
        chokeAmount = 49;
        followShapeMode = FollowShapeModeOptions.ALL_EDGES;
        bottomWidth = '0.25in';
        topWidth = '0.125in'
        rightWidth = '0.6in'
        leftWidth = '0in'
      // Gradient Feather Settings, PLEASE HELP
      $.writeln(obj.transparencySettings.gradientFeatherSettings.properties.toSource().replace(/,/g,",\n"));
      with (obj.transparencySettings.gradientFeatherSettings){
        applied = true;
        angle = 90;
        type = 1635282023/*GradientType.LINEAR*/;
       // GradientStop settings go here???????
      I am not grasping how I am supposed to get the values of the Gradient stops into the script. If you can help me with this, you can use any stop settings you have. Any help would be greatly appreciated.
      Thank you very much,
      Danny
        • 1. Re: [CS5] [JS]-Gradient Feather with Gradient Stops Question
          milligramme Level 3
          Hi
          GradientStop can access via.
          obj.transparencySettings.gradientFeatherSettings.opacityGradientStops
          it is collection of OpacityGradientStops.
            applied = true;
            angle = 90;
            with(opacityGradientStops){
              // by default, it has two stops
              for (var i=0, iL=opacityGradientStops.length; i < iL ; i++) {
                $.writeln(opacityGradientStops[i].properties.toSource());
              // you can edit
              opacityGradientStops[0].opacity = 0;
              opacityGradientStops[1].opacity = 100;
              // you can add a gradient stop, but add at end of collection
              // so remove last stop, and add again
              // do you have any nice idea?
              opacityGradientStops[1].remove();
              var mid_op_grad_stop = opacityGradientStops.add({
                opacity:50,
                midpoint:50,
              var last_op_grad_stop = opacityGradientStops.add({
                opacity:100,
                midpoint:50,
          Thankyou
          mg.
