2 Replies Latest reply on Aug 1, 2011 9:56 PM by JEShort01
    URGENT- Problems with ImporterREDServer
    inaksi prod
      I shot a feature film with red one-mysterium. 4K.
      I consntantly have ImporterREDServer crashing and soon enough, i can,t even put the footage on the source monitor. After 20 seconds I open Premiere, I get  few crashes in a row. Premiere does not crashes, just the importer.
      I have all the lates upgrades in CS5  (5.0.3)
      I can't find the problem. I alos have all the latest drivers for my hardware.
      My video card (GTX 460 SE) is hacked to be able to use with mercury engine. It usualy works fine with P2 footage.
      Any one had this problem before?
      Here is what the crash details are:
      Problem signature:
        Problem Event Name:    APPCRASH
        Application Name:    ImporterREDServer.exe
        Application Version:    0.0.0.0
        Application Timestamp:    4ce33cca
        Fault Module Name:    ntdll.dll
        Fault Module Version:    6.1.7601.17514
        Fault Module Timestamp:    4ce7ba58
        Exception Code:    c0000005
        Exception Offset:    0002e3fb
        OS Version:    6.1.7601.2.1.0.256.1
        Locale ID:    4105
        Additional Information 1:    0a9e
        Additional Information 2:    0a9e372d3b4ad19135b953a78882e789
        Additional Information 3:    0a9e
        Additional Information 4:    0a9e372d3b4ad19135b953a78882e789
      Here is my rig specs:
        > Mainboard : Asus P6T WS PRO
        > Chipset : Intel X58
        > Processor : Intel Core i7 960 @ 3200MHz
        > Physical Memory : 24576MB (6 x 4096 DDR3-SDRAM )
        > Video Card : NVIDIA GeForce GTX 460 SE
        > Hard Disk : Western Digital WD1001FALS-00J7B1 ATA Device (1000GB)
        > Hard Disk : Western Digital WD1002FAEX-007BA0 ATA Device (1000GB)
        > Hard Disk : Western Digital WD3000HLFS-01G6U4 ATA Device (300GB)
        > Hard Disk : Western Digital WD5000AAKS-00A7B0 ATA Device (500GB)
        > Hard Disk : Hitachi HDS721010CLA332 (1000GB)
        > Hard Disk : TOSHIBA MK5059GSXP (500GB)
        > DVD-Rom Drive : ATAPI iHBS212   2
        > Monitor Type : NEC Technologies LCD22WMGX - 22 inches
        > Network Card : Realtek Semiconductor RTL8168/8111 PCIe Gigabit Ethernet Adapter
        > Operating System : Windows 7 Ultimate Professional Media Center 6.01.7601 Service Pack 1 (64-bit)
        > DirectX : Version 11.00
        > Windows Performance Index : 5.9 on 7.9
        • 1. Re: URGENT- Problems with ImporterREDServer
          JEShort01 Level 4
          Inaksi,
          I don't think that it is your hardware, I think that this could be a software bug.
          I was playing with downloaded RED clips just this past Saturday with my 5.0.3 CS5 and experienced something similar, but not as bothersome as what you are seeing. Here's what I'm seeing, and here is what I found...
          My Issue is the following error when I am exiting Premiere after editing RED clips:
          "ImporterREDServer.exe has stopped working"
          Your work sounds more interrupted by this however.
          I Googled and found a thread on reduser.net where Todd Kopriva (Adobe employee) states that this problem has been fixed in 5.5, and as of 4/29/11 there was not a patch available for CS5 - 5.0.3 at that time.
          Possibly downloading and trying 5.5 will get you where you need to go. Good luck!
          Todd?
          Regards,
          Jim
          • 2. Re: URGENT- Problems with ImporterREDServer
            JEShort01 Level 4
            Inaksi,
            Totally unrelated to your ImporterREDserver issue, I would suggest that you upgrade to a 6-core, which would be a pretty easy change to implement.
            I've never seen anything tax my 4.2 GHz OC'd i7-970 on playback (MPE assisted) like the RED 4.5k files did that I was playing with.
            See:
            Where can I find Red 4k clips to download?
            http://forums.adobe.com/thread/883259?tstart=30
            Jim
