9 Replies Latest reply on Aug 6, 2011 9:47 AM by Francisc
    Programatically set itemRenderer
    Francisc Level 3
      Hello,
      How can I itemRenderers programatically? The reason I need this is that want the same list to change renderers based on user input.
      I tried this and it didn't work:
      //FirstItemRenderer extends IconItemRenderer
      var itemRenderer:FirstItemRenderer=new FirstItemRenderer();
      itemRenderer.iconWidth=40;
      itemRenderer.iconScaleMode="letterbox";
      itemRenderer.setStyle('iconDelay',0);
      //data object contains name, icon and decorator properties; the last 2 are embedded resources
      itemRenderer.labelField="name";
      itemRenderer.iconField="icon";
      itemRenderer.decorator="decorator";
      list.itemRenderer=itemRenderer as IFactory;
      list.dataProvider=acDataProvider;
      I tried this and it works, but I can't figure out how to set all of the things I could set above like iconWidth and iconField:
      list.itemRenderer=new ClassFactory(FirstItemRenderer);
      list.labelFunction=getName;
      Where getName is this:
      private function getNameitem:Object):String
          if(item.alternateName){return item.alternateName;}
          else{return item.firstName+' '+item.lastName;}
      Again, I need this because if the user clicks button 1 then FirstItemRenderer is set as the renderer for #list, while if the second button is clicked then SecondItemRenderer is set.
      Thank you.
