0 Replies Latest reply on Aug 2, 2011 1:10 AM by OlivierBerquin
    [AS] Need some advice about baseline
    OlivierBerquin
      I'm tired of "cuts" such that it:
      With an annual global production of roughly 5,000
      GW, it forms a fundamental component of […]
      You see that the 5,000 is not on the same line as the GW.
      So, I wrote a script whose
      - find a digit, a space, a character
      - in a different baseline.
      I wrote this, but is not very fast…
      So, I wonder if it is not possible to find a solution with a "whose"… Something like:
                set theSequences to (object reference of every item of theFind where baseline of character 1 is not baseline of character -1)
      set theList to {}
      set myText to ""
      set thebounds to {0, 0, 150, 150}
      tell application "Adobe InDesign CS5.5"
           set myDocument to active document
           set myWindow to active window
           set find grep preferences to nothing
           set position of find grep preferences to normal
           set find what of find grep preferences to "\\d+ ."
           tell myDocument
                set theFind to find grep
           end tell
           repeat with aSequence in theFind
                tell aSequence
                     try
                          if baseline of character 1 is not baseline of character -1 then
                               set Pagenumber to the name of parent page of parent text frames of aSequence
                               set myParentPage to parent page of parent text frames of aSequence
                               set end of theList to "page: " & Pagenumber & " | " & aSequence & return
                          end if
                     end try
                end tell
           end repeat
           set myText to every item of theList as Unicode text
           set theBlack to swatch "Black" of myDocument
           tell page 1 of myDocument
                set theFrame to make text frame with properties {geometric bounds:thebounds, contents:myText, fill color:theBlack, fill tint:20}
                -- This is a detail
                tell text frame preferences of theFrame
                     set text column count to 3
                     set text column gutter to 3
                end tell
           end tell
           -- zoom on the page
           select theFrame
           tell myWindow to zoom given fit page
      end tell
      TIA.
