0 Replies Latest reply on Aug 2, 2011 5:07 AM by SeferGER
    InDesign CS5 7.0 Silent installation?
    SeferGER
      Dear all,
      in our Company we use the Altiris Deployment solution for packaging and automatic deployment.
      We need to create a silent installation of Adobe InDesign CS5 (7.0).
      Our machines are running Windows XP SP3.
      The installation should be in language german, without an serial (trail). The serial will be inserted
      after installation from our IT-Department. All components have to be installed with the automatic
      setup.
      The folder structure from the setupfiles is the following:
      --deploy
      --packages
      --payloads
      --resources
      -Set-up.exe
      Could someone tell me which commands I have to use to install the files? I think I will also need
      an customized "install.xml", is that right?
      I am looking forward to get some answers soon.
      best regards
      Sefer
      "install.xml"
      <?xml version="1.0" encoding="UTF-8" ?>
      <Deployment>
        <Properties>
          <!-- Set this to reflect desired install location. -->
          <Property name="INSTALLDIR">C:\Program Files\Adobe</Property>
          <!-- Set this to reflect desired install language. -->
          <!-- Available languages: -->
          <!-- da_DK -->
          <!-- de_DE -->
          <!-- es_ES -->
          <!-- es_MX -->
          <!-- fi_FI -->
          <!-- fr_CA -->
          <!-- fr_FR -->
          <!-- it_IT -->
          <!-- nb_NO -->
          <!-- nl_NL -->
          <!-- pt_BR -->
          <!-- sv_SE -->
          <Property name="installLanguage">de_DE</Property>
          <!-- To serialize the application during installation, uncomment this -->
          <!-- property and replace the placeholder with your serial number.    -->
          <!-- Property name="serialNumber">xxxxxxxxxxxxxxxxxxxxxxxx    -->
        </Properties>
        <Payloads>
          <!-- AdobeInDesign7AppBase-mul -->
          <Payload adobeCode="{F9766AC1-1461-1033-B862-DF8FE1C033BE}">
            <Action>install</Action>
          </Payload>
        </Payloads>
      </Deployment>
