0 Replies Latest reply on Aug 2, 2011 10:27 AM by JasonRelish
    Issue with NativeProcess sandboxing
    JasonRelish Level 1
      I'm not complete sure that this is a sandboxing issue, but it seems like it is. I'm only not sure because I don't understand why some things here are being excluded and some aren't.
      Basically I'm writing a companion app for some other software and am using REG.EXE on Windows to determine which software is installed or not.
      If from the command line I type:
      reg QUERY HKLM\SOFTWARE\MyKey
      I get back:
      HKEY_LOCAL_MACHINE\SOFTWARE\MyKey\Key1
      HKEY_LOCAL_MACHINE\SOFTWARE\MyKey\Key2
      HKEY_LOCAL_MACHINE\SOFTWARE\MyKey\Key3
      HKEY_LOCAL_MACHINE\SOFTWARE\MyKey\Key4
      In my app I'm using this code:
      var processInfo:NativeProcessStartupInfo = new NativeProcessStartupInfo();
      processInfo.executable = new File("C:\\Windows\\System32\\reg.exe");
      processInfo.arguments = new <String>["QUERY", "HKLM\\SOFTWARE\\MyKey"];
      var process:NativeProcess = new NativeProcess();
      process.addEventListener(ProgressEvent.STANDARD_OUTPUT_DATA, onOutputData);
      process.addEventListener(ProgressEvent.STANDARD_ERROR_DATA, onErrorData);
      process.addEventListener(NativeProcessExitEvent.EXIT, onExit);
      process.addEventListener(IOErrorEvent.STANDARD_OUTPUT_IO_ERROR, onIOError);
      process.addEventListener(IOErrorEvent.STANDARD_ERROR_IO_ERROR, onIOError);
      process.start(processInfo);
      Now, for whatever reason I'm only getting this output in my app
      If I try to access Key1, Key2, Key4 I get an error that the key is invalid even though they are there. The only reason I would doubt that this is a sandbox issue is that I thought these values would all be stored in the same registry file.
      Anything that could help me solve this problem would be appreciated.
