6 Replies Latest reply on Aug 2, 2011 12:18 PM by mlhend9
    Need Help with Javascript for Acrobat Pro 9
    mlhend9
      Hello,
      I am creating a PDF form in Adobe Acrobat Profession 9.  Not having a lot of experience with Javascript, I have found this forum very helpful and have used many of the script examples for other issues I have had.  I was hoping someone could help with the following script, I have tried many variations, cannot get it to work.
      var ratio = this.getField("ratio").value
      var concentration = this.getField("concentration").value
      var result = this.getField("result").value
      if(ratio.value>=50.00)
      {result.value ='PASS';}
      if(ratio.value".value>=40.00)
      if((concentration.value ==61) && (ratio.value >= 49.25))
      if((concentration.value ==61) && (ratio.value >= 39.25))
      if((concentration.value ==62) && (ratio.value >= 48.50))
      if((concentration.value ==62) && (ratio.value >= 38.50))
      else
      {result.value = 'FAIL';}
      This is just a piece of the code  The concentration values run from 61 through 99 and the ratio value varies for each concentration value, there is a high ratio and a low ratio.  The result of this field with populate the results field with a PASS or FAIL.  This is not working......any help is greatly appreciated!
        • 1. Re: Need Help with Javascript for Acrobat Pro 9
          George_Johnson MVP & Adobe Community Professional
          Try changing this line:
          to this:
          // Get a reference to the result field
          var result = this.getField("result");
          • 2. Re: Need Help with Javascript for Acrobat Pro 9
            Actually, you need to do the same to the other similar statements at the beginning of the script.
            • 3. Re: Need Help with Javascript for Acrobat Pro 9
              mlhend9 Level 1
              Thanks George.  I updated the script to:
              var ratio = this.getField("ratio");
              var concentration = this.getField("concentration");
              if(ratio.value >=40.00)
              else
              However, I am still getting a FAIL result even when the ratio is 50.00 or equal to the passable ratio.
              • 4. Re: Need Help with Javascript for Acrobat Pro 9
                mlhend9 Level 1
                I just corrected the first part of the script to the below.  Still only produces a FAIL result
                // Get a reference to the ratio field
                // Get a reference to the concentration field
                else
                • 5. Re: Need Help with Javascript for Acrobat Pro 9
                  If this script is attached to the Calculate event of the "result" field, if I understand the logicm the code should be something like:
                  // Default
                  var res = "FAIL";
                  if (ratio.value >= 40.00) {
                      res = 'PASS';
                  if ((concentration.value == 61) && (ratio.value >= 39.25)) {
                      res = 'PASS';
                  if ((concentration.value == 62) && (ratio.value >= 38.50)) {
                      res ='PASS';
                  // Set this field's value
                  event.value = res;
                  If the code is placed elsewhere, you need to indicate where.
                  • 6. Re: Need Help with Javascript for Acrobat Pro 9
                    mlhend9 Level 1
                    You are awesome!  Thank you so much.
                    I actually was doing the calculations in another field, I moved to the result field....it is working perfectly!
