4 Replies Latest reply on Aug 10, 2011 7:49 AM by bt85260
    Invalid value for parameter 'using' of method 'export'.
    bt85260
      I am trying to export a PDF from InDesign 5.5 using AppleScript in Mac OS Lion.
      My code is in exactly the same format as shown on page 47 of the Adobe InDesign CS5, Scripting Guide: AppleScript.  This is the same in the new 5.5 guide.
      That is
      tell application "Adobe InDesign CS5.5"
      tell active document
      export format PDF type to "Macintosh HD:Users:admin:Desktop:OUTBOX:testfile.pdf" using PDF export preset "sRGB100dpi"
      end tell
      end tell
      No matter what I type in for a preset value, either a built in value or one I have created, I get the same error messge.  If I run the export without the preset, it works fine.  If I add the "without showing options" clause at the end, the code won't compile.
      My full error is:
      error "Adobe InDesign CS5.5 got an error: Invalid value for parameter 'using' of method 'export'. Expected PDF export preset, but received 1346794356." number -128
      This problem looks similar to a discussion involving InDesign Server and javascript.
      Any suggestions appreciated.
