1 Reply Latest reply on Aug 9, 2011 10:30 AM by broconne
    Partial Wipe Effect
    broconne Level 1
      Is it possible to perform a partial wipe effect in adobe flex?
      I am using a parallel wipe effect in which I am doing a wipe to remove an object from location and a second wipe to make the object appear in another location.  I am using this wipe effect to visualize a task completion.  For example, if 30% of the object is wiped away on one side and 30% is showing up in the other location, then the task is 30% done.
      Is there a way to control the wipe effect such that I can request that only X amount be performed, then later do the next X amount, etc?
      Or altenatively, is there any eventHandler I can add to the parallel effect where I can pause the effect after a certain percentage is complete?
        • 1. Re: Partial Wipe Effect
          broconne Level 1
          I have been playing with this on and off for a few days and still don't have a good solution.
          I have tried using the xFrom,yFrom,xTo,yTo properties and it still always wipes the entire image.
          Any pointers or items to look at?
