1. Re: How to achive this simple effect?
Gilberto Baldera Aug 2, 2011 11:25 PM (in response to adobo_baboy)Use a solid layer of the color of your choice then add a mask and modify its feather:
The effects which comes from photography is called vignetting or vignnete
another way is to add a spot light and animate that but its harder hope it works
2. Re: How to achive this simple effect?
adobo_baboy Aug 2, 2011 11:29 PM (in response to Gilberto Baldera)Thank you si much Sir Gilberto. But should i do this in on all of the photo? Or I need to do it somewhere in the composition are?Sorry, im a newbie in AE.
Your advice very much appreciated.
3. Re: How to achive this simple effect?
Gilberto Baldera Aug 2, 2011 11:35 PM (in response to adobo_baboy)1 person found this helpfulIn your comp go to layer new solid choose make comp size and color
then select the solid layer in your timeline (If the solid layer is not selected instead of a layer mask it will create a shape layer which is not what you need) and choose the elipse tool (or press q until the sllipe tool is chosen) and in the tool bar and click and drag an oval of the desired size then open the mask properties (or press M twice) and modify the mak feather
4. Re: How to achive this simple effect?
adobo_baboy Aug 2, 2011 11:37 PM (in response to Gilberto Baldera)Got it! Thanks so much!
5. Re: How to achive this simple effect?
Todd_KoprivaAug 3, 2011 5:48 AM (in response to adobo_baboy)
This article gives information about several ways to make vignettes.
