17 Replies Latest reply on Aug 3, 2011 2:22 PM by Rangora
    Please help with creating text area
    lingo55 Level 1
      Hi all,
      I am embarrasingly new to FLEX 4, so please excuse my questions.
      What I want to do is to create a button that inserts a text area in my canvas every time it gets clicked.
      How would I do that?
      Thanks a lot
        • 1. Re: Please help with creating text area
          kokorito Level 4
          easiest way would be to use states
          take a look at the videos here, should help you get started
          http://www.adobe.com/devnet/flex/videotraining.html
          • 2. Re: Please help with creating text area
            GordonSmith Level 4
            Write a 'click' handler for the Button that does something like
            var textArea:TextArea = new TextArea();
            textArea.x = ...;
            textArea.y = ...;
            myCanvas.addChild(textArea);
            Gordon Smith
            Adobe Flex SDK Team
            • 3. Re: Please help with creating text area
              lingo55 Level 1
              Thanks for the link Kokorito.
              • 4. Re: Please help with creating text area
                lingo55 Level 1
                Thanks Gordon,
                problem is I don't know how to create a click handler....but will do some research.
                • 5. Re: Please help with creating text area
                  lingo55 Level 1
                  OK, this is what I've done:
                  protected function create_text(evt:MouseEvent):void {
                  var RichEditableText:RichEditableText = new RichEditableText();
                  RichEditableText.x = 50;
                  RichEditableText.y = 23;
                  MyCanvas.addChild(RichEditableText);
                  And this is the code attached to my button:
                  click="create_text(event);"
                  But I get this error:
                  1046: Type was not found or was not a compile-time constant: RichEditableText. Main.mxml /src line 12 Flex Problem
                  What am I doing wrong?
                  • 6. Re: Please help with creating text area
                    kokorito Level 4
                                      xmlns:mx="library://ns.adobe.com/flex/mx"
                                      minWidth="955" minHeight="600">
                         <fx:Declarations>
                              <!-- Place non-visual elements (e.g., services, value objects) here -->
                         </fx:Declarations>
                         <s:states>
                              <s:State name="first"/>
                              <s:State name="second"/>
                         </s:states>
                         <s:Button includeIn="first" label="show text area" click="currentState='second'"/>
                         <s:TextArea includeIn="second"/>
                    </s:Application>
                    • 7. Re: Please help with creating text area
                      Rangora Level 3
                      Do not give your variable the exact class name... Your app have no way to understand if you try to work on the var or on the class.
                      • 8. Re: Please help with creating text area
                        lingo55 Level 1
                        Thanks Kokorito, but what I want to do is to insert a RichEditableText
                        every time the button is clicked
                        • 9. Re: Please help with creating text area
                          lingo55 Level 1
                          Thanks Rangora,
                          could you give me an example please?
                          TY
                          • 10. Re: Please help with creating text area
                            kokorito Level 4
                            RichEditableText is a class
                            you cant name an instance of a class the same as the class. Flex is case sensitive so you can use richEditableText or myRichEditableText
                            • 11. Re: Please help with creating text area
                              lingo55 Level 1
                              OK I've done this now:
                              var myRichEditableText:RichEditableText = new RichEditableText();
                              myRichEditableText.x = 50;
                              myRichEditableText.y = 23;
                              MyCanvas.addChild(myRichEditableText);
                              TY
                              • 12. Re: Please help with creating text area
                                kokorito Level 4
                                you have to import it first
                                import spark.components.RichEditableText;
                                • 13. Re: Please help with creating text area
                                  lingo55 Level 1
                                  OK, no more errors now..but nothing gets inserted. Here is my code
                                  <code>
                                  <s:Application
                                  xmlns:s="
                                  xmlns:mx="
                                  library://ns.adobe.com/flex/mx" backgroundColor="#F4F2F2" width="900" height="600">
                                  <s:layout>
                                  <s:BasicLayout/>
                                  </s:layout>
                                  <fx:Script>
                                  <![CDATA[
                                  myRichEditableText.width = 50;
                                  myRichEditableText.height = 23;
                                  myRichEditableText.x = 0;
                                  myRichEditableText.y = 0;
                                  myRichEditableText.text=
                                  "RichEditableText"
                                  </fx:Script>
                                  <fx:Declarations>
                                  </fx:Declarations>
                                  <s:BorderContainer x="63" y="254" width="501" height="290" borderVisible="false" dropShadowVisible="true" cornerRadius="0" id="BusinessCard">
                                  </s:BorderContainer>
                                  <mx:HRule x="63" y="237" chromeColor="#A4A4A4" height="1" width="501"/>
                                  <mx:VRule x="581" y="254" width="1" chromeColor="#A4A4A4" height="290"/>
                                  <s:Label text="85 mm" chromeColor="#B0B0B0" color="#A2A2A2" backgroundColor="#F4F2F2" width="53" verticalAlign="middle" textAlign="center" x="297" y="231"/>
                                  <s:Label text="55 mm" width="47" height="19" color="#A2A2A2" backgroundColor="#F4F2F2" verticalAlign="middle" x="574" y="388"/>
                                  <s:Button x="692" y="254"
                                  label="
                                  Insert text"
                                  </s:Application>
                                  </code>
                                  </code>
                                  </code>
                                  • 14. Re: Please help with creating text area
                                    kokorito Level 4
                                    you are adding the text area to a container called MyCanvas
                                    what is the container MyCanvas?
                                    also it is bad practice to start instance names with a capital, use lower case for instance names and capitals for class names.
                                    id="businessCard" (is that where you want the text area?)
                                    although that is really up to you but you'll appreciate it later if you get into the habit now
                                    • 15. Re: Please help with creating text area
                                      lingo55 Level 1
                                      Thanks again Kokorito. I have changed the container name to myCanvas bu still
                                      nothing gets inserted. Heres the code again:
                                      <s:Application
                                      xmlns:s="
                                      xmlns:mx="
                                      <s:layout>
                                      <s:BasicLayout/>
                                      </s:layout>
                                      <fx:Script>
                                      <![CDATA[
                                      "kljlkjlkjlkjlkjlkjlkjlkjlkjlkjlkjlkjlkj"
                                      myCanvas.addChild(myRichEditableText);
                                      </fx:Script>
                                      <fx:Declarations>
                                      </fx:Declarations>
                                      <s:BorderContainer x="63" y="254" width="501" height="290" borderVisible="false" dropShadowVisible="true" cornerRadius="0" id="myCanvas">
                                      label="
                                      Insert text"
                                      </s:Application>
                                      • 16. Re: Please help with creating text area
                                        Rangora Level 3
                                        Tried your code. Got a popup telling me :
                                        Error: addChild() is not available in this class. Instead, use addElement() or modify the skin, if you have one.
                                        Changed     myCanvas.addChild(myRichEditableText); to     myCanvas.addElement(myRichEditableText); and it worked.
                                        But you should use a HGroup, a VGroup or a TileGroup instead of a BorderContainer... You would not have to set x and y of the text area manually.
                                        • 17. Re: Please help with creating text area
                                          lingo55 Level 1
                                          THANKS!! it seems to be working now. I am in Spain and it's
                                          quite late here...I better go to bed now and con
                                          tinue with my next problem tomorrow.
                                          Thanks again
