3 Replies Latest reply on Aug 7, 2011 3:46 AM by Francisc
    IconItemRenderer with alternating icon existence
    Francisc Level 3
      Hello,
      I have an IconItemRenderer in which some rows have icons (and decorators) and some do not.
      The ones that do not, align the labelDisplay as if they would and I wanted it to be left aligned.
      Is there something I'm missing, shouldn't a null icon move the label to the left?
      I can easily override the layoutContents() method when icon is null, but I'm just curious.
      Thank you.
        • 1. Re: IconItemRenderer with alternating icon existence
          Shongrunden Adobe Employee
          Do you set an iconWidth/iconHeight on the renderer?
          • 2. Re: IconItemRenderer with alternating icon existence
            Francisc Level 3
            Ah, that's it.
            Thank you.
            • 3. Re: IconItemRenderer with alternating icon existence
              Francisc Level 3
              Here's what I did.
              //For holding default values
              private var defaultIconWidth:Number;
              private var defaultIconHeight:Number;
              //Set when overriding the set data method based on data
              private function isHeader:Boolean=false;
              override protected function measure():void
                  //Set default values for icon dimensions the first time
                  if(!defaultIconWidth){defaultIconWidth=iconWidth || getElementPreferredWidth(iconDisplay);}
                  if(!defaultIconHeight){defaultIconHeight=iconHeight || getElementPreferredHeight(iconDisplay);}
                  if(!isHeader)
                      //Reset icon dimensions to what they were set (if they were)
                      iconWidth=defaultIconWidth;
                      iconHeight=defaultIconHeight;
                      super.measure();
                  else
                      //No icon for header, set iconWidth and iconHeight to 0 so that layoutContents doesn't take the passed value from MatchDetails.mxml which is 40 into computations
                      iconWidth=0;
                      iconHeight=0;
