2 Replies Latest reply on Aug 3, 2011 10:28 PM by Steve Little
    Premiere Pro 5.5 compatibility with 32 bit video card
    Steve Little
      Hi
      I am have just purchased the student version of CS5.5 Master Collection and am about to load it on to my MacBook Pro which only has a 32 bit video card.
      In the information on the trial version (which I was using and have now uninstalled) it stated that complimentary copies of Premiere Pro CS4 would be provided when you purchase the suite for 32 bit support.
      However reading the installation PDF on the disc the 32 bit support versions only refer to Windows OS.
      There is absolutely no mention of 32 bit support for Mac?
      Am I stuck with a version of Premiere that I am unable to use because I'm on Mac?
      Just as an aside using the trial version I was able to use Premiere CS5.5 with no problem but when I exported a project to Quicktime the file was not recognised by any software and so does not play.
      Many Thanks
      Steve
        • 1. Re: Premiere Pro 5.5 compatibility with 32 bit video card
          >32 bit video card
          One - what is the exact brand and model?
          Two - as far as I know, the 64bit requirement is for the CPU and Operating System, not the graphics card
          I don't have a link handy, but I did read in another message that even if the CPU and OS are 64bit, CS5 absolutely REQUIRES the SSE (I think is the term) instruction set in the CPU's firmware, and a CPU that does not have the microcode will prohibit CS5 from installing
          • 2. Re: Premiere Pro 5.5 compatibility with 32 bit video card
            Steve Little Level 1
            OK
            I proberbly sound really dumb then - Sorry.
            So I am mixing up the bits requirement for the CPU with the bits requirement of the Graphics card.
            For the record this is my system -
            Model Name: MacBook Pro
              Model Identifier: MacBookPro4,1
              Processor Name: Intel Core 2 Duo
              Processor Speed: 2.4 GHz
              Number Of Processors: 1
              Total Number Of Cores: 2
              L2 Cache: 3 MB
              Memory: 4 GB
              Bus Speed: 800 MHz
              Boot ROM Version: MBP41.00C1.B03
              SMC Version (system): 1.27f3
              Hardware UUID: C86139CA-767F-53E9-ADF7-D0FD02C9E250
              Sudden Motion Sensor:
              State: Enabled
            And the Graphics -
            NVIDIA GeForce 8600M GT:
              Chipset Model: GeForce 8600M GT
              Type: GPU
              Bus: PCIe
              PCIe Lane Width: x16
              VRAM (Total): 256 MB
              Vendor: NVIDIA (0x10de)
              Device ID: 0x0407
              Revision ID: 0x00a1
              ROM Revision: 3212
              Displays:
            Display Connector:
              Status: No Display Connected
            H243H:
              Resolution: 1920 x 1080 @ 60 Hz
              Pixel Depth: 32-Bit Color (ARGB8888)
              Display Serial Number: LEW0C0364013
              Main Display: Yes
              Mirror: Off
              Online: Yes
              Rotation: Supported
            The only issue then is that the graphics card is not GPU acceleration compatable.
            I went ahead and loaded the software and tried exporting the Premiere Project again and the file appears to be playing fine so I would guess that was a restriction on the codexes that came with the trial version that was the issue there.
            Thanks very much for your time.
            Steve
