1. Re: Watermark script alignment on cropped photos
Bill Hunt Aug 3, 2011 6:47 PM (in response to frogmike)Mike,
Please post the steps in the Action.It could be that just an order of operations will solve the issue.
2. Re: Watermark script alignment on cropped photos
frogmike Aug 3, 2011 6:51 PM (in response to Bill Hunt)Well, the steps I have are, I start with the same type of image open, I resize to 35%, then I place a watermark sized and located exactly where I want, then lastly I merge the image, click stop. Same steps as my previous action.
-MIke
3. Re: Watermark script alignment on cropped photos
JJMack Aug 4, 2011 7:53 PM (in response to frogmike)First of all Image Size does not crop it resample your image to a different pixel size. Please read on.
Fully expand your action so you can see each step and the setting recorded for the steps. Pay close attention to all size setting and make sure they are what you are expecting. The way Photoshop records size settings depend on Photoshop current ruler units. If you record a step like Image size and set the dialog to something like 35% what get recoded depends on Photoshop current ruler units. If ruler units is percent the steps will be record as a percentage. If ruler units is pixels the Image size step will be an absolute pixel size which is 35% of the current document pixel size. If you run that action on a document that has a different pixel size the resize will not to 35% of that document it will to 35% of the size of the document the action was recorded on.
It can be tricky to record an action that will water mark any size document well. It can be done better with a script. However scripting requires programming knowledge. My crafting actions package has a sample watermarking action that add three watermarks to and size document. One using a custom shape Layer one a text layer and the third a custom color logo.
Crafting Actions Package
Contains- Action Actions Palette Tips.txt
- Action Creation Guidelines.txt
- Action Dealing with Image Size.txt
- Action Enhanced via Scripted Photoshop Functions.txt
- CraftedActions.atn Sample Action set includes an example Watermarking action
- Sample Actions.txt Photoshop CraftedActions set saved as a text file.
- 12 Scripts for actions
