2 Replies Latest reply on Aug 4, 2011 3:04 AM by Godly_Dev
    External skin files in Flex 4.5.1
    Godly_Dev Level 1
      Hi everyone,
      I am using the Flash Builder 4.5.1 with the flex 4.5.1 SDK to build a web application. The application will be distributed to many clients and they should all have their own look and feel for the application.
      Is there a way to have the application load skins from an external file during run time? If so, how does one put all the skins into 1 file instead of having them scattered across many files?
      Finally, are there ways to define a "default skin" so that if the skin for a component is not present in the external skin file, the "default skin" will be used?
      Thank you
