3 Replies Latest reply on Aug 12, 2011 7:09 AM by James Robinson
    SDK API - Map Styles to Tags (StyleExportTagMaps)
    Andres_Mendoza Level 1
      Hello everybody,
      I am developing a script to specialize the export tag mapping tool on CS5.5
      I have found an object called "StyleExportTagMaps".
      I would like to know two things:
            1. Wich object is its parent? i.e. from which Object should it be called from to create a new "StyleExportTagMap" Object. I have unsuccessfully tried to make the call from:
                • The Document Object:
                  • myStyleExportTagMapA = myDocument.StyleExportTagMaps.add(...)
                • The Paragraph Object, which is the "MyStyleExportTag" object parent (the element, but not the list):
                  • myStyleExportTagMapA = myDocument.paragraphStyles.item(myStyleAName).StyleExportTagMaps.add(...)
            2. What values should you send to the add method as parameters 1, 4, 5? i.e:
                  1. exportTypeParam:String
                  2. exportTagParam:String
                  3. exportClassParam:String
                  4. exportAttributesParam:String
                  5. withPropertiesParam:Object
      Thanks in advance,
      Andres Mendoza
        • 1. Re: SDK API - Map Styles to Tags (StyleExportTagMaps)
          Hello Evreybody,
          I have allready figuered out the object's parent, and it is definatelly a ParagraphStyleItem (but the class name doesn't begin with capital letter):
          1. The ParagraphStyle Object, e.g:
            • myStyleExportTagMapA = myDocument.paragraphStyles.item(myStyleAName).styleExportTagMaps.add( ...)
          Now I would like to know, the argument values for the 1st, 4th and 5th parameters, the add method expect to recieve (I haven't been able to create a valid StyleExportTagMap object):
          • myStyleExportTagMapA = myStyleA.styleExportTagMaps.add("1st???", myXMLTagAName, "TheExportClass", "4th???", "5th???"); i.e:
          Furthermore, what I really need to know is how do you specifically map a style to a specific Tag and class value. I was trying to use "xmlExportMaps.add()" and "mapStylesToXMLTags()" methods. It is possible to map a Style to a Tag with these methods, but I couldn't figure out how to set the class associated to the Tag (this is how I found the StyleExportMap Object, which I'm trying to use), e.g:
          • myStyleName: h2.fakecaps
          • Expected associated Tag name: h2
          • Expectede associated class name: fakecaps
          • Expected "template.css" values when exporting to ePub file: h2.fakecaps{...}
          Thanks in advance,
          Andres Mendoza
          • 2. Re: SDK API - Map Styles to Tags (StyleExportTagMaps)
            Hello Everybody,
            A possible parameter for exportTypeParam (param1) is "EPUB"; maybe you could try with "PDF"
            The Attributes String (param4) is composed by any combination of the ParagraphStyle properties.
            I hope this would be usefull to anybody.
            Ciao
            Andres.
            • 3. Re: SDK API - Map Styles to Tags (StyleExportTagMaps)
              James Robinson
              Andres,
              I have found this resource extremely helpful:
              http://jongware.mit.edu/idcsjs5.5/pc_ParagraphStyle.html
              here is the master path for CS 5.5 reference:
              As for mapping the XML tags to styles I believe you have to map styles then call that map styles function. So for example:
              xmlExportMaps.add(currentDocumentRef.paragraphStyles.item('myParaStyle'), currentDocumentRef.xmlTags.item('myXmlTag'));
              xmlExportMaps.add(currentDocumentRef.paragraphStyles.item('myParaStyle2'), currentDocumentRef.xmlTags.item('myXmlTag2'));
              currentDocumentRef.mapStylesToXMLTags();
              currentDocumentRef is a variable pointing to the current document (I usually use app.activeDocument).
              http://jongware.mit.edu/idcsjs5.5/pc_XMLExportMaps.html#add
              Hope it helps
