0 Replies Latest reply on Aug 5, 2011 4:47 AM by EricJ32
    Unable to locate specified base class 'resources.style1.HelpButtonIcon' for component class
    EricJ32 Level 1
      I have a Flex (4.1.0) project, which has many skinnable custom components. The application allows a user to choose another style which changes these skins via loading a new compiled CSS. These non-default skins are in a separate Flex project.  I've not had a problem with this method until now.
      The custom component I am skinning contains several icons which are defined in the component like this:
      [SkinPart(required="true", type="mx.core.IVisualElement")]
      public var componentIconHelp:IFactory;
      then I use the iconRendererFunction to return the appropriate component part:
      private function iconRendererFunction(item:Object):IFactory
           //truncated method
           return componentIconHelp;
      Within the skin for "style1", I then have
      <s:Skin xmlns:fx="http://ns.adobe.com/mxml/2009"
           xmlns:mx="library://ns.adobe.com/flex/mx"
           xmlns:style1="resources.style1.*">
      <!-- host component -->
      <fx:Metadata>
           [HostComponent("myApp.components.ButtonComponent")]
      </fx:Metadata>
      <fx:Declarations>
           <fx:Component id="componentIconHelp">
                <style1:HelpButtonIcon />
           </fx:Component>
      </Declarations>
      When I try to compile this, I get the "Unable to locate specified base class 'resources.style1.HelpButtonIcon' for component class 'resources.style1.ButtonComponentSkinInnerClass0'" error.
      If I remove the HelpButtonIcon from the <fx:Component> declaration, and just put it in the main body of the skin, it compiles and renders, but I need it to be a component (there's multiple components I have to choose from to display, similar to the ButtonBar skin).
      Any ideas why it's not compiling and what I need to do to achive this?
