0 Replies Latest reply on Aug 4, 2011 4:31 AM by DrBarash
    Connect to Data wizard with IBM Websphere problem
    DrBarash Level 1
      Hello,
      I am trying to use the flash builder connect to data wizard (Data -> connect to webservices).
      my client is flex 4.5 application, and my server is a normal JEE 5 application running on IBM Websphere 7 server.
      I don't use BlazeDS, CF or anythig else...
      Now, the tricky part:
      JEE 5 server creates the webservice on it's own, including the wsdl files.
      When I try using the connect to data wizard, and use a wsdl and an xsd deployed by IBM Websphere, I get an error:
           There was an error during service introspection.
             Referenced file contains errors (http://localhost:9080/advisor-server/AS/AS_schema1.xsd).
      When I deploy exactly the same application on Oracle Glassfish server, all works well.
      The problem is that the client demmanded Websphere....
      Any ideas?
      Thank you all
