4 Replies Latest reply on Aug 5, 2011 4:31 AM by JJ0330
    AppleScript - gradient ramp location?
    JJ0330
      Hi, we are looking to control gradient ramp location from AppleScript.  I think this is what it is because if go into swatch options for gradient created with below code, it has an option for Gradient Ramp where you can put in a percentage so we'd like to be able to do that somehow in AppleScript. Tried various options in the make new gradient properties because able to control name and type there but not sure how to control the gradient ramp?
        set ColorA to make color with properties {model:process, color value:{50, 0, 0, 0}, name:"Color A"}
        set ColorB to make color with properties {model:process, color value:{0, 0, 0, 0}, name:"Color B"}
        set GradAtoB to make new gradient with properties {name:"GradA-B", type:linear}  --Is there any option here?
        set stop color of first gradient stop of GradAtoB to ColorA
        set stop color of last gradient stop of GradAtoB to ColorB
        set fill color of first rectangle to GradAtoB
      Joe
        • 1. Re: AppleScript - gradient ramp location?
          JJ0330 Level 1
          I think I can get it to work as below but looks like setting the length is by inches but would like to do by percent if possible?
            set ColorB to make color with properties {model:process, color value:{50, 0, 0, 0}, name:"Color B"}
            set gradient fill angle of rectangle 1 to 90
            set fill color of the first rectangle to GradAtoB
            set gradient fill length of first rectangle to 1   --Can we do percentage?
          Thanks.
          • 2. Re: AppleScript - gradient ramp location?
            Larry G. Schneider Adobe Community Professional & MVP
            That may well be a 0 to 1 as 0% to 100% so the middle would be 0.5. You may have to try it to confirm.
            • 3. Re: AppleScript - gradient ramp location?
              Muppet Mark Level 5
              You change ramp points and stop locations in your gradient… Midpoint is in range 13-87. Gradient length and start point are for using like dragging the gradient tool…
              tell application "Adobe InDesign CS5"
                   tell document 1
                        set ColorA to make color with properties ¬
                        {model:process, color value:{50, 50, 10, 0}, name:"Color A"}
                        set ColorB to make color with properties ¬
                        {model:process, color value:{0, 50, 100, 0}, name:"Color B"}
                        set GradAtoB to make new gradient ¬
                        with properties {name:"Gradient A-B"}
                        set location of first gradient stop of GradAtoB to 10
                        set location of last gradient stop of GradAtoB to 80
                        set midpoint of last gradient stop of GradAtoB to 70
                        set gradient fill angle of the first rectangle to 45
                   end tell
              end tell
              • 4. Re: AppleScript - gradient ramp location?
                JJ0330 Level 1
                Great, that will work.  Thanks.
