9 Replies Latest reply on Aug 4, 2011 12:48 PM by Colin Brougham
    Export adds 200MB to a 13MB clip
    bgrenham
      Greetings,
      Unfortunately I have run into a bit of an issue when exporting from CS5.
      I have trimmed about 10 seconds off a small 14MB Quicktime clip and when I export, as a Quicktime file, it comes out as more than 200MB.
      Am I doing something wrong?  I have completed the same, seemingly, quick and easy process in iMovie and it does not add hundreds of MB's.
      Seems like I shouldnt have to compromise the quality of such a small clip by adjusting settings when my only intention is to shorten it (make it even smaller).
      Any help would be appreciated!
      Cheers,
      Billy
        • 1. Re: Export adds 200MB to a 13MB clip
          Colin Brougham Level 6
          What's your input codec? What's your output codec? What's your input bitrate? What's your output bitrate?
          • 2. Re: Export adds 200MB to a 13MB clip
            bgrenham Level 1
            Thanks for the reply -- here's what I got.
            Let me know if this not what you asked for.
            Cheers,
            Billy
            Output: 720x480, 29.97 (fps), Lower, Quality 100
            32000 Hz, Stereo, 16bit
            DV25 NTSC
            Source: 720x480 (0.9091), 29.97 fps, Lower, 00;00;44;26
            48000 Hz, Stereo
            • 3. Re: Export adds 200MB to a 13MB clip
              Unfortunately, that doesn't really help. Grab MediaInfo and run a report on both your source file and your exported file; if you use Text mode, you can copy and paste the results of each here.
              • 4. Re: Export adds 200MB to a 13MB clip
                BVX3001 Level 1
                That's odd. If you have any other items on the same sequence timeline, make sure that you are exporting only the work area, not the entire sequence. Look at the bottom of the Export Settings panel: Source Range.  I've been bitten by that occasionally.
                • 5. Re: Export adds 200MB to a 13MB clip
                  bgrenham Level 1
                  See below -- thanks!
                  Source:
                  General
                  Complete name                    : /Users/lacsmac/Desktop/IAMS MEDIA/ROCKSTARREVEALCTA 56.mov
                  Format                           : QuickTime
                  Format/Info                      : Original Apple specifications
                  File size                        : 12.7 MiB
                  Duration                         : 1mn 3s
                  Overall bit rate                 : 1 685 Kbps
                  Encoded date                     : UTC 2011-07-20 19:08:52
                  Tagged date                      : UTC 2011-07-20 19:09:44
                  Writing library                  : Apple QuickTime
                  Video
                  Format                           : AVC
                  Format/Info                      : Advanced Video Codec
                  Format profile                   : Main@L3.0
                  Format settings, CABAC           : No
                  Format settings, ReFrames        : 2 frames
                  Codec ID                         : avc1
                  Codec ID/Info                    : Advanced Video Coding
                  Duration                         : 1mn 3s
                  Bit rate                         : 1 522 Kbps
                  Width                            : 640 pixels
                  Height                           : 360 pixels
                  Display aspect ratio             : 16:9
                  Frame rate mode                  : Constant
                  Frame rate                       : 23.976 fps
                  Color space                      : YUV
                  Chroma subsampling               : 4:2:0
                  Bit depth                        : 8 bits
                  Scan type                        : Progressive
                  Bits/(Pixel*Frame)               : 0.276
                  Stream size                      : 11.4 MiB (90%)
                  Language                         : English
                  Color primaries                  : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
                  Transfer characteristics         : BT.709-5, BT.1361
                  Matrix coefficients              : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
                  Audio
                  Format                           : AAC
                  Format/Info                      : Advanced Audio Codec
                  Format profile                   : LC
                  Codec ID                         : 40
                  Duration                         : 1mn 3s
                  Bit rate mode                    : Constant
                  Bit rate                         : 128 Kbps
                  Channel(s)                       : 2 channels
                  Channel positions                : Front: L R
                  Sampling rate                    : 44.1 KHz
                  Compression mode                 : Lossy
                  Stream size                      : 961 KiB (7%)
                  Language                         : English
                  Material_Duration                : 63089
                  Material_StreamSize              : 984707
                  Exported:
                  General
                  Complete name                    : /Users/lacsmac/Desktop/Exported Projects/IAMS.Rockstar_reveal.mov
                  Format                           : MPEG-4
                  Format_Commercial_IfAny          : DVCPRO
                  Format profile                   : QuickTime
                  Codec ID                         : qt
                  File size                        : 208 MiB
                  Duration                         : 58s 458ms
                  Overall bit rate                 : 29.8 Mbps
                  Encoded date                     : UTC 2011-08-02 23:40:22
                  Tagged date                      : UTC 2011-08-02 23:40:33
                  ©TIM                             : 00;00;00;00
                  ©TSC                             : 2997
                  ©TSZ                             : 100
                  Video
                  Format                           : DV
                  Codec ID                         : dvc
                  Bit rate                         : 24.4 Mbps
                  Width                            : 720 pixels
                  Height                           : 480 pixels
                  Display aspect ratio             : 4:3
                  Original display aspect ratio    : 4:3
                  Frame rate                       : 29.970 fps
                  Standard                         : NTSC
                  Color space                      : YUV
                  Chroma subsampling               : 4:1:1
                  Bit depth                        : 8 bits
                  Scan type                        : Interlaced
                  Bits/(Pixel*Frame)               : 2.357
                  Stream size                      : 201 MiB (97%)
                  Language                         : English
                  Audio #1
                  Format                           : PCM
                  Format settings, Endianness      : Little
                  Format settings, Sign            : Signed
                  Codec ID                         : sowt
                  Bit rate                         : 1 024 Kbps
                  Sampling rate                    : 32.0 KHz
                  Bit depth                        : 16 bits
                  Stream size                      : 7.14 MiB (3%)
                  Language                         : English
                  Audio #2
                  Format                           : PCM
                  Muxing mode                      : DV
                  Muxing mode, more info           : Muxed in Video #1
                  Bit rate                         : 1 536 Kbps
                  Sampling rate                    : 48.0 KHz
                  Bit depth                        : 16 bits
                  Stream size                      : 0.00 Byte (0%)
                  Menu
                  Language                         : English
                  Encoded date                     : UTC 2011-08-02 23:40:33
                  • 6. Re: Export adds 200MB to a 13MB clip
                    bgrenham Level 1
                    Thanks for the tip but unfortunately "work area" was already selected.
                    Will definitely keep an eye out for that in the future!
                    BG
                    • 7. Re: Export adds 200MB to a 13MB clip
                      Well, you're going from an H.264 encoded clip at about 1.5 Mbps to a DV encoded clip at about 25 Mbps; should be pretty clear as to why the file is larger.
                      If you have to go back to H.264, either use QuickTime H.264 or H.264 MP4, and set your bitrate (the biggest determinant of filesize) accordingly. Note that since you're going from a highly-compressed source file back to a highly-compressed destination, you'll incur some quality loss. You can match your encoding parameters to the source parameters as reported by Mediainfo.
                      • 8. Re: Export adds 200MB to a 13MB clip
                        bgrenham Level 1
                        Thanks for all the info Colin.  I am still trying to find the right combo to keep the quality from taking a noticable hit.
                        I might just use iMovie for minor edits like this.
                        Thanks again!
                        Cheers,
                        Billy
                        • 9. Re: Export adds 200MB to a 13MB clip
                          iMovie might do "smart encoding" from H.264 QuickTime clips, meaning that it won't re-encode the whole file if it doesn't have to. Premiere Pro doesn't work like this, unfortunately, so you might be better off sticking with iMovie for such things. As far as actual editing capabilities, of course, Premiere Pro steals iMovie's lunch money
