1 Reply Latest reply on Aug 4, 2011 1:26 PM by Julian Hirjoi
    Process completed when route choices failed.  Shouldn't the process have stalled?
    RayHundley
      We have a process where after a step there are three route choices.  Each route checks the value of a process variable, let's call it ReviewType.  Each of the three route choices is looking for a different value.  Those are:
      Initial
      Mid-year
      Final
      The problem comes wherein earlier in the process the ReviewType variable was set to an incorrect value;  in this case it was the value "Inital" instead of "Initial". It was my understanding that if a step has multiple route to evaluate and none pass the process should stall.  But in this case the process completed.  We have tried modifying the "Initial" route evaluation by adding an OR condition to also look for "Inital" but that does no good because the process is marked as complete.
      Any ideas on how we can get this completed process going again?
      Ray
        • 1. Re: Process completed when route choices failed.  Shouldn't the process have stalled?
          Julian Hirjoi
          If there are no routes to continue the process, the process will be marked completed. There are no errors or exceptions to place the process in stalled state. You would have to find a way to restart the completed processes and continue from the desired step. One approach would be to create another process that filters, if you don't know already, completed processes for your special condition and, after you updated the main process to allow an intermediate starting point, restart the necessary completed processes...
          I hope it helps...
