0 Replies Latest reply on Aug 5, 2011 12:18 AM by isabelle loyer
    Simultaneous httpservice in the same component
    isabelle loyer Level 1
      Dear Flexer,
      I created an Air application.
      On loading my component, I'd to make simultaneous request to my database to load some data to my component.
      My component is a form with several comobobox and and text field.
      But to do that I have two major problem.
      - Sometimes, my form (my component) is loaded but there no information  in my text field, perhaps request is not finished? but how to verify  that and how to solve.
      - Other question, as requests with http service is for different table,  one to load sudent, other to load note, other to load teaching , is it  possible to do this request in the same php file and to get all thos  informations with the same E4X file.
      Thanks for help
      [Code]
      <windowSkin:NativeTitleWindow xmlns:fx="http://ns.adobe.com/mxml/2009"
        xmlns:mx="library://ns.adobe.com/flex/mx"
        xmlns:windowSkin="fr.intersystemes.ui.windowSkin.*"
        xmlns:skins="fr.intersystemes.ui.skins.*"
        xmlns:tabBarClasses="flexlib.controls.tabBarClasses.*"
        minWidth="800" minHeight="800" borderVisible="false"
        creationComplete="onLoad(event)"
        currentState="tb1"
        dropShadowVisible="false"
        skinClass="fr.intersystemes.ui.windowSkin.NativeTitleWinSkin">
      <windowSkin:states>
      <s:State name="tb1"/>
      <s:State name="tb2"/>
      <s:State name="tb3"/>
      <s:State name="tb4"/>
      <s:State name="tb5"/>
      <s:State name="tb6"/>
      </windowSkin:states>
      <fx:Declarations>
      <!-- Placer ici les éléments non visuels (services et objets de valeur, par exemple). -->
      <s:HTTPService id="phpPatientDetail"
         showBusyCursor="true"
         useProxy="false"
         resultFormat="e4x"
         method="POST"
         result="detailPatient(event)"
         fault="trace(this + event.fault.toString());">
      </s:HTTPService>
      <s:HTTPService id="phpLoadTypeDossier"
         useProxy="false"
         resultFormat="e4x"
         method="POST"
         result="allDossier(event)"
      </s:HTTPService>
      <s:RadioButtonGroup id="rbsex"/>
      </fx:Declarations>
      <fx:Metadata>
      [Event(name="myEventClose", type="fr.intersystemes.ui.windowSkin")]
      </fx:Metadata>
      <fx:Script>
      <![CDATA[
      import fr.intersystemes.VO.PatientVO;
      import fr.intersystemes.config.urlManager;
      import fr.intersystemes.util.DateUtility;
      import fr.intersystemes.util.FileSerializer;
      import fr.intersystemes.util.UserPrefs;
      import mx.collections.ArrayCollection;
      import mx.events.FlexEvent;
      import mx.events.IndexChangedEvent;
      import mx.events.ItemClickEvent;
      import mx.rpc.events.ResultEvent;
      import spark.events.IndexChangeEvent;
      [Bindable]
      public var monIdPatient:String;
      private var pg:UserPrefs;
      [Bindable]
      public var PAT_TB_ARRAY:ArrayCollection = new ArrayCollection (
      [{label:"Personnelles"},
      {label:"Assuré & Sécu. Soc"},
      {label:"Compléments perso"},
      {label:"Autres adresses"},
      {label:"Cursus"},
      {label:"Archives"}]
      [Bindable]
      private var DP_PAT_CIVIL:ArrayCollection = new ArrayCollection (
      [{label:"Monsieur"},
      {label:"Madame"},
      {label:"Mademoiselle"},
      {label:"Le Jeune"}]
      [Bindable]
      private var DP_PAT_ADRDEF:ArrayCollection = new ArrayCollection (
      {label:"Madame"},
      {label:"Le Jeune"}
      [Bindable]
      private var DP_PAT_DOS1:ArrayCollection = new ArrayCollection (
      [{label:"N° Etudiant"},
      {label:"N° INEE"},
      {label:"Liberer"}
      [Bindable]
      private var DP_PAT_DOS2:ArrayCollection = new ArrayCollection (
      {label:"N° INEE"},
      {label:"Liberer"}
      [Bindable]
      private var DP_PAT_TEL:ArrayCollection = new ArrayCollection (
      [{label:"Maison"},
      {label:"Bureau"},
      {label:"Pére"},
      {label:"Mére"}]
      protected function onLoad(event:FlexEvent):void
      this.pg = FileSerializer.readObjectFromFile("prefSaisiePat.up") as UserPrefs;
      var urlPatient:urlManager = new urlManager();
      phpPatientDetail.url=urlPatient.urlService() + "loadStudentById.php";
      var paramsPatient:Object = new Object();
      paramsPatient.idPatient = monIdPatient;
      phpPatientDetail.send(paramsPatient);
      phpLoadTypeDossier.send();
      private function onMyEventClose(e:Event):void
      private function allDossier(event:ResultEvent)
      private var objectPatient:PatientVO;
      private function detailPatient(event:ResultEvent):void
      trace(this + event.result.toString());
      var resultXml:XML = event.result as XML;
      var aNode:XML;
      var list:Array = new Array();
      // we use resultXml.children() (and not resultXml..customer)
      var dateConv : DateUtility = new DateUtility();
      trace ("result" + resultXml.children().length());
      for each (aNode in resultXml.children())
      objectPatient = new PatientVO();
      objectPatient.paIndex = Number(aNode.@id);
      objectPatient.paNomP = aNode.@np ;
      objectPatient.paPrenom = aNode.@pr ;
      objectPatient.paCodePostal = aNode.@cp;
      objectPatient.paDossier1 = aNode.@d1;
      objectPatient.paDossier2 = aNode.@d2;
      objectPatient.paNaissance = dateConv.dateStringToObject(aNode.@dn);
      objectPatient.paNumTel1 = aNode.@tel;
      lNom.text = objectPatient.paNomP;
      lPrenom.text = objectPatient.paPrenom;
      //lAge.text = dateConv.calculAgeAn(objectPatient.paNaissance) as String;
      lAge.text = " - " + dateConv.calculAgeAn(objectPatient.paNaissance) + " ans et " + dateConv.calculAgeMois(objectPatient.paNaissance) + " mois";
      lNaissance.text = "Né(e) le " + dateConv.dateToStringFR(objectPatient.paNaissance);
      this.title = objectPatient.paNomP + " "+ objectPatient.paPrenom;
      fdNom.text = objectPatient.paNomP;
      dfNaissance.text = dateConv.dateToStringFR(objectPatient.paNaissance);
      private function reloadPatient():void{
      private function tbClickEvt(evt:IndexChangeEvent):void {
      // Access target TabBar control.
      //var targetComp:TabBar = TabBar(evt.currentTarget);
      switch(evt.target)
      case 0:
      currentState="tb1";
      break;
      case 1:
      currentState="tb2";
      break;
      case 2:
      currentState="tb3";
      break;
      case 3:
      currentState="tb4";
      break;
      case 4:
      currentState="tb5";
      break;
      case 5:
      currentState="tb6";
      break;
      default:
      currentState="tb1";
      break;
      </fx:Script>
      <s:Group width="100%" height="100%">
      <s:layout>
      <s:BasicLayout/>
      </s:layout>
      <s:Image x="0" y="0" width="53" height="53" click="reloadPatient()"/>
      <s:VGroup x="100" y="8" width="100%" gap="5" verticalAlign="top"> <!-- Groupe central-->
      <s:HGroup> <!-- Nom prenom-->
      <s:Label text="Nom" id="lNom" fontWeight="bold"/>
      <s:Label text="Prénom" id="lPrenom" fontWeight="bold"/>
      </s:HGroup>
      <s:HGroup width="100%"> <!-- Naissance-->
      <s:Label text="Naissance" id="lNaissance" />
      <s:Label text=" / Age" id="lAge"/>
      </s:HGroup>
      </s:VGroup >
      <s:VGroup x="730" y="0" horizontalAlign="right" verticalAlign="top" paddingLeft="5"> <!-- Modif-->
      <s:Label text="Crea" id="lCrea"/>
      <s:Label text="Modif" id="lModif"/>
      </s:VGroup>
      <!-- Partie avec onglet-->
      <s:ButtonBar x="0" y="74" dataProvider="{PAT_TB_ARRAY}" change="tbClickEvt(event);"/>
      <s:Form x="0" y="94" id="foPerso" width="100%" height="100%" includeInLayout="true" includeIn="tb1">
      <s:layout>
      <s:FormLayout gap="3" paddingLeft="0"/>
      </s:layout>
      <s:HGroup width="100%" gap="3" horizontalAlign="left" resizeMode="noScale"
        verticalAlign="baseline" >
      <s:DropDownList id="cbQualite" dataProvider="{DP_PAT_CIVIL}"/>
      <s:FormItem label="Nom" >
      <s:TextInput id="fdNom" width="200" focusColor="#D55E5E" focusEnabled="true"
      tabIndex="1" text="Mon nom"/>
      </s:FormItem>
      <s:FormItem  label="Prénom" >
      <s:TextInput id="fdPrenom" width="200" tabIndex="2"/>
      </s:FormItem>
      <s:DropDownList id="cbDossier1" dataProvider="{DP_PAT_DOS1}" width="118" height="22" tabIndex="3"/>
      <s:FormItem label="" >
      <s:TextInput id="fDossier1" width="90" paddingRight="5" tabIndex="4"/>
      </s:FormItem>
      </s:HGroup>
      <s:Group>
      <s:FormItem label="Naissance" tabIndex="5" >
      <mx:DateField id="dfNaissance" width="100" editable="true" formatString="DD/MM/YYYY" yearNavigationEnabled="true"/>
      </s:FormItem>
      <s:RadioButton x="90" y="0" label="Masculin" group="{rbsex}" tabIndex="6"/>
      <s:RadioButton x="170" y="0" label="Féminin" group="{rbsex}" tabIndex="7"/>
      <s:DropDownList id="cbDossier2" x="340" y="0" width="118" height="22"
      dataProvider="{DP_PAT_DOS1}" tabIndex="8"/>
      <s:FormItem x="460" y="0" label="" tabIndex="9">
      <s:TextInput id="fDossier2" width="90" paddingRight="5"/>
      </s:FormItem>
      </s:Group>
      <s:HGroup width="100%" horizontalAlign="left" resizeMode="noScale" verticalAlign="baseline">
      <s:FormItem label="Qualité" tabIndex="10">
      <s:DropDownList id="cbQualiteParent" width="130"/>
      </s:FormItem>
      <s:FormItem label="Nom" tabIndex="11">
      <s:TextInput id="tiNomPar" width="200" text="NomParent"/>
      </s:FormItem>
      <s:FormItem label="Prénom" tabIndex="12">
      <s:helpContent>
      <s:VGroup>
      <s:Label text="Prénom du responsable" />
      </s:VGroup>
      </s:helpContent>
      <s:TextInput id="tiPrenomPAr" width="200"/>
      </s:FormItem>
      </s:HGroup>
      <s:FormItem label="Adresse par défaut"  tabIndex="12" >
      <s:DropDownList id="cbAdrDef" dataProvider="{DP_PAT_ADRDEF}"/>
      </s:FormItem>
      <s:FormItem label="Adresse" tabIndex="13">
      <s:TextInput id="tiAdr1" width="480" text="Adr"/>
      <s:TextInput id="tiAdr2" width="480"/>
      </s:FormItem>
      </s:HGroup>
      <s:FormItem label="Code Postal" tabIndex="14">
      <s:TextInput id="tiCP" text="CP" width="65"/>
      </s:FormItem>
      <s:FormItem label="Ville" tabIndex="15">
      <s:TextInput id="tiVille" text="Ville" width="250"/>
      </s:FormItem>
      <s:FormItem label="Pays" tabIndex="16">
      <s:TextInput id="tiPays" text="Pays" width="175"/>
      </s:FormItem>
      </s:HGroup >
      <s:HGroup height="20" horizontalAlign="left" resizeMode="noScale" verticalAlign="baseline" paddingTop="5">
      <s:Label text="Téléphones"/>
      <s:Spacer width="39" height="20"/>
      <s:Label text="SMS"/>
      </s:HGroup>
      <s:DropDownList id="paTabTel1" dataProvider="{DP_PAT_TEL}" tabIndex="17"/>
      <s:CheckBox id="cbSMS1" selected="true" tabIndex="18"/>
      <s:TextInput id="paTel1" width="120" text="Tel1" tabIndex="19"/>
      <s:TextInput id="paRemTel1" width="480" text="RemTel1" tabIndex="20"/>
      </s:HGroup>
      <s:DropDownList id="paTabTel2" dataProvider="{DP_PAT_TEL}" tabIndex="21"/>
      <s:CheckBox id="cbSMS2" selected="true" tabIndex="22"/>
      <s:TextInput id="paTel2" width="120" text="Tel2" tabIndex="23"/>
      <s:TextInput id="paRemTel2" width="480" text="RemTel2" tabIndex="24"/>
      </s:HGroup>
      <s:DropDownList id="paTabTel3" dataProvider="{DP_PAT_TEL}" tabIndex="25"/>
      <s:CheckBox id="cbSMS3" selected="true" tabIndex="26"/>
      <s:TextInput id="paTel3" width="120" text="Tel3" tabIndex="27"/>
      <s:TextInput id="paRemTel3" width="480" text="RemTel3" tabIndex="28"/>
      </s:HGroup>
      <s:FormItem label="Télécopie">
      <s:TextInput id="paFax" width="120" text="Fax" tabIndex="29"/>
      </s:FormItem>
      <s:FormItem label="Email">
      <s:TextInput id="paMail" width="333" text="Mail" tabIndex="30"/>
      </s:FormItem>
      </s:HGroup>
      <s:FormItem label="Prof. des parents">
      <s:TextInput id="paProfPar" width="180" text="Prof Par" tabIndex="31"/>
      </s:FormItem>
      <s:FormItem label="du père">
      <s:TextInput id="paProfPere" width="180" text="du père" tabIndex="32"/>
      </s:FormItem>
      <s:FormItem label="de la mère">
      <s:TextInput id="paProfMere" width="180" text="de la mère" tabIndex="33"/>
      </s:FormItem>
      </s:HGroup>
      <s:Line width="100%" height="3"/>
      <s:FormItem label="Rub1" >
      <s:layout>
      <s:HorizontalLayout/>
      </s:layout>
      <s:TextInput id="paUserR1" width="220" text="Rub1" tabIndex="34"/>
      <s:CheckBox id="cbRB1" tabIndex="35"/>
      </s:FormItem>
      <s:FormItem label="Rub5">
      <s:layout>
      </s:layout>
      <s:TextInput id="paUserR5" width="220" text="Rub5" tabIndex="36"/>
      <s:CheckBox id="cbRB5" tabIndex="37"/>
      </s:FormItem>
      </s:HGroup>
      <s:FormItem label="Rub2">
      <s:layout>
      </s:layout>
      <s:TextInput id="paUserR2" width="220" text="Rub2" tabIndex="37"/>
      <s:CheckBox id="cbRB2" tabIndex="38"/>
      </s:FormItem>
      <s:FormItem label="Rub6">
      <s:layout>
      </s:layout>
      <s:TextInput id="paUserR6"  width="220" text="Rub6" tabIndex="39"/>
      <s:CheckBox id="cbRB6" tabIndex="40"/>
      </s:FormItem>
      </s:HGroup>
      <s:FormItem label="Rub3">
      <s:layout>
      </s:layout>
      <s:TextInput id="paUserR3"  width="220" text="Rub3" tabIndex="41"/>
      <s:CheckBox id="cbRB3" tabIndex="42"/>
      </s:FormItem>
      <s:FormItem label="Rub7">
      <s:layout>
      </s:layout>
      <s:TextInput id="paUserR7"  width="220" text="Rub7" tabIndex="43"/>
      <s:CheckBox id="cbRB7" tabIndex="44"/>
      </s:FormItem>
      </s:HGroup>
      <s:FormItem label="Rub4">
      <s:layout>
      </s:layout>
      <s:TextInput id="paUserR4"  width="220" text="Rub4" tabIndex="45"/>
      <s:CheckBox id="cbRB4" tabIndex="46"/>
      </s:FormItem>
      <s:FormItem label="Rub8">
      <s:layout>
      </s:layout>
      <s:TextInput id="paUserR8"  width="220" text="Rub8" tabIndex="47"/>
      <s:CheckBox id="cbRB8" tabIndex="48"/>
      </s:FormItem>
      </s:HGroup>
      </s:Form>
      </s:Group>
      </windowSkin:NativeTitleWindow>
      [/Code]
