3 Replies Latest reply on Aug 5, 2011 4:37 AM by [Jongware]
    [JS ID CS5] I fail to use move instead of copy
    Michiel Koers Level 1
      Hello everyone,
      A little while ago I started working on my first InDesign script. It is a script that places a Word file in an InDesign-file and then searches for tags. Text between these tags needs to be moved to certain text frames already in the InDesign file. So far things are working great. However, I read on this forum that it is better and faster to use the move function instead of using select, cut and paste to move text to a different text frame. I can't get this to work.
      This is the working script i use to copy/paste some text to the appropiate frames.
      app.findGrepPreferences.findWhat = "<paragraaf1>.+</paragraaf1>";
      var gevondenTag1 = myDocument.findGrep();
      app.cut(app.selection = gevondenTag1);
      app.select(bestaandTextFrame1.parentStory.insertionPoints.item(0));
      app.paste();
      As I said, this works ok. But since i want to run this script on about 600 Word files, speed is an important factor. So i tried to use move.
      The script I wrote and doesn't work is this:
      bestaandTextFrame1.parentStory.insertionPoints.item(0).move(LocationOptions.before, gevondenTag1)
      Does anyone have an idea what i'm doing wrong? How can I get this to work?
      Thanks in advance!
      Michiel Koers,
      Mediadesigner at M-effect
      www.meffect.nl
        • 1. Re: [JS ID CS5] I fail to use move instead of copy
          Mac_06 Level 2
          Though not tested... but should work.
          var myDocument = app.activeDocument
          var bestaandTextFrame1 = app.activeDocument.textFrames.itemByName("Test")
          app.selection=gevondenTag1
          app.selection[0].move(LocationOptions.before, bestaandTextFrame1.parentStory.insertionPoints.item(0))
          Mac
          • 2. Re: [JS ID CS5] I fail to use move instead of copy
            Thanks a lot. Works like a charm!
            Michiel
            • 3. Re: [JS ID CS5] I fail to use move instead of copy
              Note that there is no need to 'move' the gevondenTag1 array into app.selection.
              findGrep returns an array of found objects, and you can use that immediately in the next line:
              gevondenTag1[0].move(LocationOptions.before, bestaandTextFrame1.parentStory.insertionPoints.item(0))
              (This also gives you a hint on how to use a for..loop to iterate over all found items, not just the first one.)
