5 Replies Latest reply on Aug 5, 2011 8:58 AM by Amy Blankenship
    Bind one column to two fields in spark data grid
    mikmiki
      hi,
      igave a spark datagrid that uses a GridItemRenderer with a RichText label display.
      the RichText column needs to display two or more fields in diffrenet sizes and colors.
      how can i bind the column to two or more fields?
      any help would be great.
        • 1. Re: Bind one column to two fields in spark data grid
          Amy Blankenship Level 4
          You should be able to use a labelFunction to wrap appropriate formatting around the various values.  For example:
          private function formatLabel(item:Object, column:GridColumn):String {
               var result:String = '<span fontSize="12">'+item.someField+'</span>';
               result += '<span color="#FF0000">'+item.someOtherField+'</span>';
               return result;
          • 2. Re: Bind one column to two fields in spark data grid
            mikmiki Level 1
            not working.it's just displaying the column as : '<span fontSize="12">'+somedata+'</span>';
                 result += '<span color="#FF0000">'+someOtherdata+'</span>';
            • 3. Re: Bind one column to two fields in spark data grid
              That looks like you didn't set up the labelFunction properly in your datagrid column.  Can you post your actual code?
              • 4. Re: Bind one column to two fields in spark data grid
                mikmiki Level 1
                yes.
                my label function is:
                private function list_labelFunc(item:Object, column:GridColumn):String
                var result:String = '<span fontSize="12">'+item.InstrumentName+'</span>';
                result +=
                '<span color="#FF0000">'+item.SystemName+'</span>';
                return result;
                /* return markupSystem.replace("INSTRUMENTNAME",data.InstrumentName).replace("SYSTEMNAME",data.Syst emName)); */
                my grid column defenition  is:
                <s:GridColumn id="colName" labelFunction="list_labelFunc" headerText="Name" itemRenderer="renderers.OpenPositionsItemRenderer" >
                and my item renderer is:
                <s:GridItemRenderer
                xmlns:fx="http://ns.adobe.com/mxml/2009"
                xmlns:s="
                library://ns.adobe.com/flex/spark"
                xmlns:mx="
                library://ns.adobe.com/flex/mx" clipAndEnableScrolling="true">
                <fx:Script>
                <![CDATA[
                import mx.collections.ArrayCollection;
                import spark.components.Grid;
                import flashx.textLayout.elements.TextFlow;
                import spark.utils.TextFlowUtil;
                var markupSystem:String = "<p>INSTRUMENTNAME</p><p>SYSTEMNAME</p>";
                override public function prepare(hasBeenRecycled:Boolean):void {
                lblData.text = data[column.dataField]
                override public function set data(value:Object):void
                var myOwner = super.grid as Grid;
                super.data = value;
                var myOwnerDataProvider:ArrayCollection = myOwner.dataProvider as ArrayCollection;
                var myIndex:int = myOwnerDataProvider.getItemIndex( data );
                var i : uint;
                if(myOwner.selectedIndex !=myIndex)
                if(myIndex % 2 == 0)
                c.color=0x525252;
                else
                c.color=0x2C2C2C;
                else
                c.color=0x355180;
                if(column.columnIndex==1)
                var flow:TextFlow = TextFlowUtil.importFromString(markupSystem.replace("INSTRUMENTNAME",data.InstrumentName).replace("SYSTEMNAME",data.SystemName));
                lblData.textFlow = flow;
                </fx:Script>
                <s:Rect id="rect" top="0" bottom="0" right="0" left="0">
                <s:fill>
                <s:SolidColor id="c" color="#2C2C2C"/>
                </s:fill>
                </s:Rect>
                <s:RichText id="lblData" textAlign="center" color="#DADADA" alpha="0.5" top="20" left="20"/>
                </s:GridItemRenderer>
                • 5. Re: Bind one column to two fields in spark data grid
                  Try changing
                  to
                  lblData.textFlow = TextFlowUtil.importFromXML(XML(column.dataField));
                  and also changing the label function to wrap the whole return in <p></p> so that it will evaluate as valid XML
                  HTH;
                  Amy
