8 Replies Latest reply on Aug 12, 2011 9:47 AM by the_wine_snob
    Half of my imported files do not import the entire file?
    VJAW
      I recently shot some high speed video using 2 Phantom high speed cameras. After converting the clips form their raw format to AVIs at 5 fps, I imported them into Premiere Pro CS5 to put together a side by side comparison. All of the AVIs imported into Premiere, however approx. half of the clips didn't fully import. For example a clip that is supposed to be 01:09:24:13 is coming in at 00:00:28:27. It's not a random compression, because when I compare the clip playback in premiere it does indeed represent the first 28 seconds of the AVI. I tried converting the files again in the Phantom software. One of the clips I was able to import and get the entire clip, however subsequent attempts for the others has not achieved the same result. I even attempted to import the clips into Premiere Pro CS3 on another workstation with the same results.
      If anyone has seen a problem similar to this, a work around or a fix would be greatly appreciated, I'm on the clock on this one.
      VJAW
        • 1. Re: Half of my imported files do not import the entire file?
          the_wine_snob Level 9
          Welcome to the forum.
          Though with different file types, I have encountered similar - file Duration is mis-read in PrPro. Obviously, something in that/those file(s) header is being missed by PrPro. I have yet to find out what. As per your case, it seems to be with random files from what should otherwise be a simple group of the same file types, with the same exact conversion settings.
          In my case, I get handed a lot of different file formats, and just use a conversion program to get those to DV-AVI (in my case) for SD Projects. Often, I will have a situation, rather like yours, where I will have 5 files, whose specs. all match up (same camera and settings in your case), and the conversion will be batched, and all resultant files identical. From time to time, one of those converted files will exhibit the same characteristics, as you observe. VLC, or other players, will see the full Duration, as will G-Spot, or MediaInfo. However, PrPro is missing something in that one file, and the Duration is heavily truncated, just as has happened to you. Quite by accident, I found that my PremiereElements program had no such issues with the "bad" file. It would Import and see the correct Duration, where PrPro could not. I just Imported, dragged to the Timeline, and then Exported to the same exact file settings, DV-AVI. The resulting file was identical to the problem DV-AVI that I had Imported. G-Spot and MediaInfo say it exactly the same. Various file "comparisson" programs could find no differnces between the two files, yet PrPro now saw the Duration correctly. I only wish that I could tell what went wrong, regarding the Duration in the originally converted file, and then the one that I just Imported and Exported from PrE, but I have never found the difference. I have opened the files in hex-editors, and gone line by line, and cannot find anything different between the two - but something IS different.
          While I have no fix for you, I can add slight comfort by saying, "I've seen very similar, and in similar cases - conversion." My "workaround" involves some extra steps (plus an extra Export), in another Adobe program (in my case), so is not ideal. However, now that I know to be on the lookout for the possibility, I just watch those Durations closely, knowing that I might need to work on one, or more, of those files, to get PrPro to see the proper Duration.
          Good luck, and maybe someone can offer us both a totally fail-safe method.
          PS - I have encountered this with my old-fav, and generally flawless DigitalMedia Converter 2.7, plus several other highly recommended conversion progams, so it does not seem specific to any one conversion program.
          • 2. Re: Half of my imported files do not import the entire file?
            Jim_Simon Level 8
            converting the clips...to AVI
            Using what codec?
            • 3. Re: Half of my imported files do not import the entire file?
              VJAW Level 1
              Bill,
              Unfortunately Due to the scaled down properties of Premiere Elements I can't use it for this particular project.
              I doing a straight 30fps non drop frame output with an output size of 256 x 256 square pixels.
              Thanks anyway
              • 4. Re: Half of my imported files do not import the entire file?
                VJAW Level 1
                I don't know what codec.
                Why?
                • 5. Re: Half of my imported files do not import the entire file?
                  In my case, I do not edit in PrE, but use it as just a "conversion" program, to fix this one problem, when it arises. All editing is in PrPro.
                  Can you give us the full specs. for the files, that fail? Maybe something will stick out in those specs.
                  • 6. Re: Half of my imported files do not import the entire file?
                    Jim_Simon Level 8
                    Why?
                    Because some work well, and others don't.
                    • 7. Re: Half of my imported files do not import the entire file?
                      VJAW Level 1
                      Solved my dilemma using Windows Movie maker.  When I took the files into elements I had the same problem. When I took the files into Movie Maker I was able to open the files the proper length and saved them out using the exact settings of my AVIs.  I'm still waiting on the codec info to come but the project is now done and gone.
                      Thanks for the assistance, and the ideas.
                      VJAW
                      • 8. Re: Half of my imported files do not import the entire file?
                        Good news, and glad that WMM worked as a conversion program.
                        Good luck, and thanks for reporting your success.
