7 Replies Latest reply on Aug 6, 2011 6:40 AM by LukeElChul
    adding to an arrary?????
    LukeElChul Level 1
      is there away to add the unit what gets attached to the array as unit4 and has an instance of unit4 and then if u press it again as unit5 with instance of unit5 and so on.......
      this is my array.
      var unitA:Array=[unit,unit1,unit2];
      var unit = 0;
      function addunit() {
           if (cash>=50) {
              var unit = attachMovie("unit", "unit"+units, _level0.getNextHighestDepth(), {_x:100, _y:100});
               unit += 1;
               cash -= 140;
      unit_btn.onRelease = addunit;
        • 1. Re: adding to an arrary?????
          You could try using the push method of the Array class...
          var unit = 0;
               if (cash>=50) {
                   unit += 1;
                   cash -= 140;
                   unitA.push(unit);
          • 2. Re: adding to an arrary?????
            LukeElChul Level 1
            That didnt work i need it on the array so when it attaches it will work with another script
            could i do a trace are something to see if it goes on the array
            • 3. Re: adding to an arrary?????
              Try it without having two things named the same: unit vs unit
              • 4. Re: adding to an arrary?????
                LukeElChul Level 1
                i done as u said and i put a trace in.
                and i get this
                _level0.unit,_level0.unit1,_level0.unit2,NaN
                • 5. Re: adding to an arrary?????
                  LukeElChul Level 1
                  i changed it a bit and now i get this
                  _level0.unit,_level0.unit1,_level0.unit2,_level0.unit
                  but it still dosent work with this script.
                  import mx.transitions.Tween;
                  import mx.transitions.easing.*;
                  for(var i:Number = 0;i<unitA.length;i++){
                  var unitB = unitA[i];
                  unitB.ivar=i;
                  unitB.onRelease = function(){
                  this.onMouseUp = function(){
                  var t1:Tween = new Tween(this, "_x", None.easeNone, this._x, _xmouse, 10, true);
                  var t2:Tween = new Tween(this, "_y", None.easeNone, this._y, _ymouse, 10, true);
                  dy = _root._ymouse-this._y;
                  dx = _root._xmouse-this._x;
                  radianrotation = Math.atan2(dy, dx);
                  radianrotation = radianrotation*180/Math.PI;
                  this._rotation = radianrotation;
                  delete this.onMouseUp;
                  • 6. Re: adding to an arrary?????
                    Your earlier code was wrong... too many things named "unit" (4 of them I believe, you should only have 1), so without seeing what you've changed it to, there's no telling what the problem might be.  But you could try using...
                    unitA.push(this["unit"+units]);
                    depending on what tat has changed to
                    • 7. Re: adding to an arrary?????
                      LukeElChul Level 1
                      i might just rewright my moving script
                      Thanks!!!!!!!! anyway for all your help
