1 Reply Latest reply on Aug 6, 2011 12:34 PM by Francisc
    Change icon position based on boolean var
    Francisc Level 3
      Hello,
      I have a custom mobile renderer extending the IconItemRenderer.
      In the set data overriding function I set a boolean variable isOpposite to be false when content should flow normally (on the left) and true when it should be right-aligned.
      This is how I change that for the labelDisplay:
      override protected function commitProperties():void
          super.commitProperties();
          var styleDecl:CSSStyleDeclaration
          //Update styling for labelDisplay
          if(isOpposite)
              styleDecl=styleManager.getMergedStyleDeclaration(".toRight");
          else
              styleDecl=styleManager.getMergedStyleDeclaration(".toLeft");
          if(styleDecl)
              labelDisplay.styleDeclaration=styleDecl;
              labelDisplay.styleChanged("styleName");
      How can I do that for the iconDisplay please? I tried various things and they failed so far. I'd preffer a CSS solution is such exists and no other is better.
      Thank you.
        • 1. Re: Change icon position based on boolean var
          Francisc Level 3
          This is how I solved this (no CSS), but I have a bad feeling about it.
          For one thing, it positions the labelDisplay and iconDisplay twice, once in the super call then in the overriden method.
          override protected function layoutContents(unscaledWidth:Number,unscaledHeight:Number):void
              super.layoutContents(unscaledWidth,unscaledHeight);
              if(isOpposite)
                  //Left so that it keeps the distance from edge compared to left aligned elements
                  var paddingLeft:Number=getStyle("paddingLeft");
                  //If iconWidth or iconHeight are not specified set them
                  if(!iconWidth){iconWidth=iconDisplay.getLayoutBoundsWidth();}
                  if(!iconHeight){iconHeight=iconDisplay.getLayoutBoundsHeight();}
                  //Override positioning of label and icon to be right aligned
                  setElementPosition(labelDisplay,paddingLeft,(unscaledHeight-getElementPreferredHeight(lab elDisplay))/2);
                  setElementPosition(iconDisplay,unscaledWidth-paddingLeft-iconWidth,(unscaledHeight-iconHe ight)/2);
          Is there a better way to do this?
          Again, I'm looking to right align the labelDisplay and iconDisplay when isOpposite is true.
