3 Replies Latest reply on Aug 7, 2011 5:22 AM by Andrew Yoole
    Add/remove shadow
    Jon_003
      My problem is the shadow located on the corner of the garage.  I have multiple angles, some with the shadow and some without.  Should I add or remove the shadow from the garage? And whats the best approach? Also, this is a video and the characters arms cross in front of the shadow frequently.
        • 1. Re: Add/remove shadow
          Andrew Yoole MVP & Adobe Community Professional
          Removing the shadow will take a large amount of rotoscoping, plus motion tracking if the camera is not stable within each shot.
          Depending on the position of your character and the amount of movement, it may be easier to add the shadow in the closer shot than remove it in the wider shot.
          But you have other problems.  The overall light intensity is quite different between the two angles, so you'll need to do some clever grading to try and match them.  And the red-shirt guy has quite different shadows on his body due to the change in sun position.  There's not much at all you can do to fix that.
          • 2. Re: Add/remove shadow
            Jon_003 Level 1
            Ok adding the shadow works best anyways.  The shots are still so no motion tracking is necessary.  Now, is there an easy way to apply the effect even though the actors arms are crossing through the shadow frequently?
            • 3. Re: Add/remove shadow
              Tht's where rotocoping comes in.  You're going to have to mask the arm movement frame by frame. There's not enough contrast between the arm colour and the background colour to do a key or auto-trace.  It has to be done by hand.
