2 Replies Latest reply on Aug 7, 2011 6:22 PM by drkstr_1
    Call another project inside a project?
    Adrien.
      Lets assume you have project 1 and project 2. Both have main.xml
      in porject 1 you click a button called x. x then lanuches project 2's main.xml which then populates a whole new window with new contentend and actions and all that good stuff.
      How ever. When installing - you install both projects as one project. When updating, you update the projects as if they were one project. so if you make a change (in either project), and then do the required changes to the appoprriate files and push it to the server - Air should pop up and say "Application Y has an update"
      How is this done? Can it be done?
